Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Sony Wega kdf-55wf655 rear projection set keeps turning on and off
I just moved and don't know if the move may have damaged my tv. It is 2 1/2 years old Sony kdf-55wf655. The TV will stay on for about a min, perfect picture and sound...then it turns itself off. The green standby light flashes about 30-32 times. Then the TV turns back on...piture first, the green light flash about 7-8 more times the the sound comes on. The green light becomes steady for about a min. Then it starts over again. Any ideas of what would cause this to happen and if it could have happened on the moving truck?
  • 7 more comments
  • fxkid Jan 19, 2008
    This is unbelievable timing. I have same problem with my TV. Just moved as well, all my connections are secure. I have reset the power and still happens. Exactly as posted by crabbie95...30 to 40 blinks, picture comes back, then sound after a few more blinks. TV is 3 years old.
  • evogt500 Jan 19, 2008
    Got the same problem but my tv has not gone moved from its usual place, so i believe that moving it from one house to the next is not the problem. I did find that we all have had our tvs for about 2 1/2 to 3 years. I read on another website that replacing the bulb will fix the problem. I hope it works...
  • rk7nair Feb 16, 2008
    I have sony wega KF-42WE610 rear projection tv, about 3years old. Now the picture & sound turn off itself every 3-mins. Stays off for about 1-2minutes and turns back on consistently. The power buttons stays on solid green can anyone help please.
  • Anonymous Mar 29, 2008
    YES I HAVE THE SAME PROBLEM SONY KDF55WF655
    ..... LOOKS LIKE THE BULB IS DRAWING TO MUCH CURRENT... THAT 30 SECOND ON/OFF IS AN INDICATOR THAT THE BULB NEEDS REPLACEMENT.
    3/29/08
  • divco70 Apr 13, 2008
    How funny is this? I'm the fifth person in two months to post the on-off, green blinking problem. Calling Ciruit City to activate my warranty... Great job, Sony.
  • abewakil08 Apr 29, 2008
    I got the exact same problem and I don't know what is wrong with it.
    Anyone can help?
  • Anonymous Jun 16, 2008
    I have the same problem too..just started last night..I talked to Sony and they said they couldn't help and to contact their repair service...My TV is 3 years old and this is the first problem we have had..hopefully it will be the only one!
  • fxkid May 11, 2010
    I too changed the beulb as recommended. TV works, but I don't seem to have same picture quality as before. Picture not as sharp, not even on hif def channels. Any suggestions?
  • helenplepci
    helenplepci Nov 13, 2012
    mine 6 years old and has just done the same but frikken hell the lamp is so expensive to fix it i might as well buy a new tv instead
Had exact same problem with my KDF-55WF655 and put in new projection bulb assembly and no more cut out plus picture is much brighter even on standard. Next time will just by bulb and install in old assembly as it looks straight forward now that I know what assembly looks like. Got about 7200 hrs. out of OE projection lamp and almost 4 years service.
Posted on Oct 01, 2009
If picture quality is poor, be sure you aligned the bulb in the correct manner and be sure the cover for the bulb is not loose. Also, you might want to re check you picture setting as it might have gotten reset when you pulled the plug (I hope you pulled the plug when replacing the bulb).
Heres another solution (maybe temporary) to the problem of no picture and no sound for 30 seconds. I had my tv's power saving setting on "standard" before. After I switched it to "reduced", the problem was fixed. It has been almost two weeks without the problem. I think its a good fix until the new bulb comes in the mail.
Posted on Jan 23, 2008
  • Sony Master
  • 8,617 Answers
Sounds like a loose connection. I would try making sure the wire harnesses are all secure in their clips.
Posted on Jan 18, 2008
Changing the bulb is the best solution, Changing the power consumption settings is only a temporary fix and you should always have a replacement bulb on hand.
Bulb life really depends on how many hours of use it has. If you watch tv more or turn it on and off frequently, bulb life will decrease. That is why people have problems as early as 2 years and some 4 to 5.
Currently I still have my original bulb that came with the TV. I had problems with it in January and its now June. But I do have a new bulb ready.
Posted on Jun 01, 2008
Guess, I'm the 6th person to report the same problem in the past month. I started experiencing this about 4 months ago, but by changing the power consumption mode from normal to reduced my TV worked fine, until today. Now it won't stay on for more than a minute. Great Job Sony - $3500 for a TV that works for two years.
Update.....as suggested by a few people I replaced the lamp,(bulb) and sure enough, back to normal. Thank you all for your help. Oh...it was an easy fix too.. me just a few seconds. Thanks again
Posted on Jan 22, 2008
    New Friend:
1/31/2010 So loved my Sony KDF55 Wf6555 bought it 1/2005. Had to replace the lamp 5/2009 the guy couldn't believe it lasted so long... 4 months later went again... not happy, of course only a 90 day warranty so I again spent the $ for another lamp w/ prayers I could get at least a year...nope just 4 months!!!! I am so upset. I found the lamp online for $84 -90 where did everyone get there's? The TV place chargeded me $199
Posted on Feb 01, 2010
3 Suggested Answers
SOURCE:
  • 586 Answers
SOURCE: I have a grand wega kdf-55wf655 projection tv.
The detail of your fault is given below according to the SELF DIAGNOSTIC SYSTEM.
The description is given below:
6 : Low B error When no "DD 6V " is detected, pin 129 of TV-micro is low and it turns off the main power.
Suggestion:
This problem is little bit technically difficult, therefore i advise you to please contact any expert who can handle this or contact SONY SERVICE CENTER.
Hope you will understand my saying.
Thanks for using fixya.
Posted on Jul 02, 2009
  • 86 Answers
SOURCE: Sony KDF 55WF655 rear Project tv Power/standby light flashing
This would be an error code indicating a problem.  You didn't mention if anything else was going on with the TV as in no picture, or no sound.  If the TV is operating just fine, there could be a bug in the software causing this.  If there is a problem, the best thing would be to contact Sony and relay that error message and go from there.
Posted on Mar 26, 2009
After turning on my sony kdf-55wf655 tv for 3-4 minutes it automatically fades out to a blk screen (also no sound) and the green power light starts to blink. the tv stays in this status for appox 2-3...
The projection lamp,the sign of it life is over.The projection lamp been in the tv about 1 1/2 or 2 years,used the tv on and watches at least 4 or 5 hours a day?It time,to replace it,with a new projection lamp.
Aug 06, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV comes on stays on for a short time than goes black with loss of sound green flashing light untill TV comes back on. takes maybe 2 min.
Jul 11, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv picture and sound comes on and off
You probably have a bad lamp sony part number A-1085-447-A XL2200 if your model number is KDF-55WF655. I recommend using original from sony 199.99 retail.
May 23, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony 55" rear projection tv
TIGHTEN THE BULB --AFTER YOY CLEAN THE DUST OFF THE BULB VENTS ON THE BULB ITSELF. PROBLEM SOLVED. EASY--CHEAP. Hey it worked for me. My picture was turning off blinking 29 times for picture 37 times for audio. This was the first issue with my KDF-55WF655 since I unwrapped it almost 5 years ago......... ITS STILL ON!!! I hope this helps someone.
Feb 14, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Bad picture
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
http://splinke.googlepages.com/sonyrearprojectionlcdtv-opticalblock
Jan 19, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony TV Screen
Is you model listed below?
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
My sony tv will not stay on
If you replace the lamp and need to reset the Lamp Timer Reset procedure is: With The Set In Standby Press Display, 5, Vol Up, Power on the remote control Press Jump 3. Or, To Display The Lamp Time Press 2 Nine Times. To Reset Press 3, Mute, Enter. One of these should work on your model. Make sure you replace the bulb first. There is a possibility that the ballast could be damaged by a defective bulb as well.
Jan 18, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
7,435 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
