Question about Dishwashers
Lady Kenmore dishwasher stops every couple of minutes during cycle
Dishwasher stops during cycle for a minute or two, starts up again and repeats this behavior several times during cycle. Displaying Error code E7, E8 codes also.
  • johnrsyring Aug 16, 2008
    My Lady Kenmore Dishwasher just started displaying the E8 error codes. What does that mean?
SOURCE: Kenmore Ultra Wash Dishwasher - 665 - 13783
dcvxzcxzcxzczxc
Posted on Feb 26, 2008
SOURCE: smeg code E8
I have exactly same problem. Have you solved it yet..
Posted on Aug 30, 2008
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Posted on Apr 21, 2009
  • 83 Answers
SOURCE: Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Posted on Jul 02, 2009
iwillfixforu
  • 619 Answers
SOURCE: My Kenmore dishwasher makes an intermittent
The crackling noise is something caught in the pump housing area. This may eventually wash out but usually disassembly is reguired.
Posted on Feb 24, 2010
Whirlpool quiet partner II starts and stops. What should I check?
the first thing to do is unplug it for 3 minutes then check to see if it reset by running
Jan 07, 2018 | Whirlpool 24 in. DU951PWB Free-standing...
Dishwasher motor starts and stops
Hey Bill,
Not professing to be any kind of a dishwasher repairman but I have had a similar issue with the start and stop thing and it turned out to be the timer motor had started to go, and in going it 'burned' a couple of sets of the contacts as well. Check with a local appliance repair centre and see first if they agree with me, and if they have anyone who can rebuild the timer - Typically not too hard to get access to and remove - In my case in Canada, it had to go to Toronto pre-paid but $70 was cheaper then a new dishwasher and it's worked great for years
Feb 09, 2014 | KitchenAid Dishwashers
Bosch dishwasher beeping during cycle
Take the front kick panel off and see if anything under the machine is wet.
Jan 06, 2014 | Bosch Evolution 800 SHE58C02UC 24 in....
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
Dishwasher does not drain...stops in cycle...no matter what cycle
HI, this is a control fault. the logic chips are malfunctioning. these chips are responsible for initiating the proper washing cycle sequences. you will need to replace this damaged control board asap.
Click here to order your new control board online.
Jun 04, 2009 | Maytag MDBH955AWS Stainless Steel 24 in....
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore altra wash dishwasher, no water
Check the water inlet solenoid and the float.
Jun 02, 2017 | Dishwashers
Dishwashers Logo
305 people viewed this question
Top Dishwashers Experts
