Question about Sony ICF-M33RDS AM/FM/RDS Radio
Radio Locked I cannot get into my radio, it has a key symbol displayed and three flashing '0'. It will not turn off. Any help appreciated. Thanks
PRESS THE "HOLD" BUTTON ON THE TOP OF THE CASE TO UNLOCK
Posted on Jul 25, 2010
Change clock on Pontiac g6
There is 2 different radios. With or without rds. Here are the instructions for both.
Setting the Time for Radios with Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED displays. If the time is not available from the station, NO UPDATE displays.
RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it can take a few minutes for the time to update.
Setting the Time for Radios without Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes flash. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
Mar 08, 2015 | Pontiac G6 Cars & Trucks
How to set the clock on a 2008 chevy cobalt
Setting the Clock (H-clock symbol, O-pwr symbol, f-music note symbol)
Without Date Display
AM/FM Base Radio with a Single CD Player
This type of radio has a
H
button for setting the time.
You can set the time by following these steps:
1. Turn the ignition key to ACC/ACCESSORY or
ON/RUN. Press the
O
knob, located in the
center of the radio, to turn the radio on.
2. Press the
H
button until the hour begins flashing
on the display. Press the button a second time and
the minute begins flashing on the display.
3. While either the hour or the minute numbers are
flashing, turn the
f
knob, located on the upper
right side of the radio, clockwise or counterclockwise
to increase or decrease the time.
4. Press the
H
button again until the clock display
stops flashing to set the currently displayed time;
otherwise, the flashing stops after five seconds and
the current time displayed is automatically set.
To change the time default setting from 12 hour to
24 hour, press the
H
button and then the pushbutton
located under the forward arrow label. Once the
time 12H and 24H are displayed, press the pushbutton
located under the desired option to select the default.
Press the
H
button again to apply the selected default,
or let the screen time out
Dec 27, 2014 | 2008 Chevrolet Cobalt
Scanner pro 93
reset it one more time and let the scanner boot before you do any thing else chill out for while dont be so egor
Sep 26, 2013 | Radio Communications
I have a Scanner I purchased from Radio shack and My niece played with it and locked every channel out and I cant get anything on it it doesnt say what kind it is but the code on the back of it is c101153...
It's impossible to give you a definite answer without knowing the make and model of your scanner, but if your display is showing a key or a lock, look for a key that has a symbol that looks like a key or a lock. With the scanner ON, press and hold that key until the display symbol clears. I hope this helps.
Bill B.
Listening in since the 60's
Dec 19, 2010 | Uniden BC60XLT-1 Handheld Scanner
I have a Pro-95 scanner that I enjoy alot, the problem is that the keypad seems to be locked, sound and squelch work fine but not a single button, I've tried the reset button several times. Any help would...
Look at the keyboard and find the button the shows the symbol for a key and a symbol for a light bulb. Press the FUNC button and then the key indicated above. The words key unlocked should appear in the display. Repeat the process to lock the keys again.
Jul 11, 2010 | Radio Shack Pro-95 Handheld Scanner
How do i get the channels to change on vx10 radio selector does not seem to change them radio recently repaired by yaesu and user manual not much help
The dial is probably locked. Look for a little padlock symbol on the display. Check the user manual for Dial or keyboard lock. Generally on Yaesu radios you use the function key plus a keyboard key. If the keyboard is labeled, you should see something that looks like a padlock next to the correct function key.
Feb 11, 2010 | Vertex Yaesu Radio FTH2009, FTH7009...
How to enter security code on kenwood dnx5220bt?
Hi, I just looked for answers and found the below mentioned procedure.
This was posted previously on another post. ....
Procedure:
01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are from STEP 05
07. Call 1 800 537 5140
08. Press 1 then #. You’ll hear Invalid Code, try again
09. Press 139010 then #. You will be asked to enter your four or six digit code followed by *
10. Enter the number from STEP 6 then *
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC
Your radio is now un-locked and usable This will surely help you. THanks Kanu
Oct 15, 2009 | Kenwood DNX7100 Car Video Player
Unlocking stereo for 2001 Oldsmobile Alero
Try this.
Here's another variation that worked for me just two days ago... you DO NOT NEED to take it to the dealer and you do NOT need to disconnect the battery, this can all be done with a couple clicks on your radio and call into that phone number.
Procedure:
14. Press the AM/FM button. The radio display changes to SEC Hope this works, Good luck. Leadispenser
Aug 24, 2008 | Car Audio & Video
Locked keys
Hi. I have a different Jwin model radio to yours, but they might have this in common: is there a 'hold' button on yours? If so, this is used to 'lock' all the buttons so that you don't switch it on/ change stations etc accidentally. Look for a 'key' symbol on your display, and press AND HOLD the 'hold' key until the symbol disappears. Pressing the 'hold' button briefly will make the symbol re-appear, and lock the keys again.
May 18, 2007 | Jwin JX-M20 AM/FM Radio
Sony ICF-M33RDS AM/FM/RDS Radio Logo
154 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
