Question about IBM 3500 Typewriter
When typing sometimes the bottom half of the letters do not show up. The Hammer solenoid is only a couple of months old. The lower case j, q,y, etc. are the worst.. Thank you in advance for your help..
  • Risbell Jan 18, 2008
    Thank you, I checked that and everything looks good..
    But it is still doing the same thing.
Check it and it looks to be fine. This has been driving me crazy.
Posted on Jan 21, 2008
  • IBM Master
  • 3,594 Answers
Check to see that the platen is fully seated in the side frames, the black latches do crack and allow the laten to raise up.
Posted on Jan 19, 2008
  • 1 more comment
  • Dick O Reilly Feb 11, 2008
    Remove the ribbon and look at the impressions are they in a realively straight line if not check the light blue ribbon latch they do break.
  • Dick O Reilly Nov 05, 2008
    It sure sounds like the platen (black rubber roller) is not seated press down firmly on both ends.
  • Dick O Reilly Feb 13, 2009
    Perhaps the person that replaced the print solenoid didn't tighten the screws and they have worked loose.
  • 139 Answers
Make sure the ribbon cartridge is fully seated...try removing it and reinserting it to make sure there are no labels or paper jammed under it.
Posted on Jan 18, 2008
The bottom half of the letters typed dont show up
Press down firmly on both ends of the platen (black rubber roll) it should snap into place, if it comes back out one of the latches is broken and will need replaced.
Feb 17, 2014 | IBM 6787 - 6787 Wheelwriter 30 Series Ii
Wheel is missing letters, broke off I guess. Does the wheel get old and fall apart? I haven't used the type writer in a few months. Should I get another wheel or call for repair? Thanks! Karen
The wheel usually last for many years. I'm assuming you are getting 2 vert lines in place of the missing letter (hammer face). Used replacement wheels are available for 29,95.
Cleveland Business Machines
Jan 31, 2011 | IBM Wheelwriter 6 Typewriter
My Wheelwriter 5 types faded and incomplete letters. We changed to a new ribbon, but problem is still there. Seems the pressure is not hard enough.
The solenoid for the hammer is probably sticky or the pad is worn.
This requires disassembly for cleaning, lube or replacing the pad.
Jan 25, 2010 | IBM Wheelwriter 30 Typewriter
Letters now well formed
first of all check out replacing the ribbon cartridge.if the cartridge is got torn or over replace the ribbon . There is a solenoid down to the left of the horseshoe shaped printwheel mount. If it is gummed up or the nylon hammer plate is broken or missing the hammer will not strike the printwheel and you will not get print out or broken letters on print. Check the solenoid with a thin screwdriver by pulling and pushing the plate and rod in and out as if you were trying to make the solenoid push the hammer toward the type wheel. If the hammer moves when you bush the solenoid then it may be gummed up or not getting electrical impulse. If it moves but the hammer doesn't move then the cushion at the tip of the solenoid is missing and the gap is to great for the solenoid to act upon the hammer.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 12, 2010 | IBM Office Equipment & Supplies
Wheelwriter 3 Selector Assembly
The selection motor bearings just right of the print solenoid get dry a little WD40 on the front and rear bearings usually takes care or this.
Dec 14, 2009 | Lexmark Wheelwriter 3 Typewriter
Type Bold letters
There is no bold feature on a WW3 you must upgrade to a WW 10 or 15 to get bold. There was at one time a bold printwheel but I haven't seenone for years.
Jul 01, 2009 | IBM Office Equipment & Supplies
IBM Pers. Wheelwriter 2 Ques
check the position of your paper drum maybe he is little uper or not on the place.
May 08, 2008 | IBM Wheelwriter 30 Typewriter
Ibm wheelwriter 5
Most likely the plastic cap on the print solenoid is broken they are available but are a bit tricky to install.
Mar 27, 2008 | IBM Wheelwriter 30 Typewriter
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
IBM 3500 Typewriter Logo
47 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
