Question about Dyna-Glo (PPH16-LP) Utility Heater
Dyna glo workhorse heater
I have a dyna glo workhorse heater that will puff black smoke when trying to ignite. the digital indicator on the side indicates F 1. i think this is the photo cell having problems can you help?
  • joeblow3 Feb 20, 2008
    cannot trust this heater- kerosene-only will ignite about half the time and smells of vaporized kerosene because wont ignite- when is running is fine-cleaned ignitor-put new kerosene in-wiped cell clean -checked hoses and pickup tube-I give up!! also works a little better if u keep filled way to top! also indicator is exactaly on red line (210000) btu
  • Anonymous Mar 02, 2009
    Identical problem as joe blow3
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
The most common problem is a lack of air pressure. Air pressure is supplied by a pump attached the the motor shaft. Dirty air filter elements can inhibit the intake of air. The pump may be dirty internally also...especially if the fan does not spin freely when flicked. The black tubes transfer the air pressure to the nozzle and they crack and leak after awhile. the fuel filter in the tank can become clogged and the black fuel-to-nozzle line can leak also. The flame sensor can be faulty or dirty if your unit starts okay but goes out after a few seconds. Observe the spray pattern, it should be a very fine vee spray pattern. A dirty nozzle can inhibit ignition. The ignitor should spark when the unit is first turned on and be positioned at the edge of the spray pattern. Most of these units have a circuit control board which lights with a green LED if power is on to the board. Failure to turn on the spark or the motor when power to the board is OK...means a bad board. Power can be checked at the black and white leads from line voltage to the spade on the board.
Posted on Dec 14, 2012
You need to pull top cover off. And bend the igniter in to the spray of fuel and check the gap of the ignighter to 3.5 mm and bingo should work i just bought one and had to do this to it
Posted on May 06, 2009
I just turned on my dyna-glo kerosene topedo type heater and it run for about 10 seconds without igniting and then shuts off with a red flashing indicator light on!
the photo electric cell is not working
it is doesn't see fire , it shuts off the fuel so that excess fuel is not going to the chamber that can cause an explosion or fire if it ignites
new items , take it back for a warranty check or refund
for older units tale it to a service agent for repairs
Dec 08, 2016 | Dyna-Glo Heating & Cooling
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
Jan 12, 2016 | Heating & Cooling
Fuel shut off switch
Replace the thermostat.
Jan 23, 2014 | Dyna-Glo Heating & Cooling
I just replaced the wick, cleaned up the heater and filled with new K-1 kero. The heater (Dyna-Glo RMC-95-C7) is emitting black smoke worst than ever. The wick is burning a little unevenly.
Either the wick was improperly installed or you may not have allowed enough time for the wick to soak in the kerosene and become evenly distributed. Check the placement of the new wick and allow time (several hours) for the wick to absorb the kerosene.
Jan 31, 2011 | Dyna-Glo RMC-8001SS Heater
What is white kerosene and can the pinkish kerosene be used in a heater?
White kerosene (K-1) is the same as the red. The red just has a dye added. You could check with your heater manufacturer but I do not think it makes a difference. Some convience stores around the house sell the clear, most sell the red. I think the started adding the red dye to indicate farm use for tax purposes.
Feb 10, 2010 | Dyna-Glo RMC-8001SS Heater
My Dyna Glo heater forced air heater worked great last year. I run it on Diesel and ran it empty before putting it away for the summer. Went to fire it up and it wouldn't work. Replaced all of the cracked...
the filter in the tank line is partially clogged with gel from useing diesel fuel you should really use a anti gel agent when running a sulphur type fuel in a unit designed for white gas/ keosene
Jan 20, 2010 | Kitchen Ranges
Surges then a big puff of smoke and it shuts down
Jan 02, 2010 | Reddy Heater-30-55,000 BTU Variable
E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Feb 03, 2008 | Dyna-Glo (PPH16-LP) Utility Heater
Dyna-Glo (PPH16-LP) Utility Heater Logo
1,898 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
