Question about Dual DWM-3900 System
Sanyo DWM-3900 Hello, I had posted a problem that was answered by MakikiChris, I took his advice but it did not fix my problem. I was advised to check my regen setting and that was correct. When I put a DVD in my unit it winds up and reads for a mnute, but after a minute it spits out the DVD and replys with a Disk Error. please advise. I have checked the ends of the wire strips they look good with no sight of and cracked or damaged conectors.
  • BigWest Feb 29, 2008
    Screen is stuck of "progressive scan mode" I can't get rid of it
  • ferrarilover Dec 19, 2008
    i have the saame problem as you when ever i put in a dvd it starts up spinning and everything but after like a minute it opens up and says disc err. at first it was both the cd's and dvd's and i was only able to listen to cd's when it was in the progressive scan mode but somehow i got the cd to play in regular mode but i still cant get dvd's to play. so just wondering is this some kind of maulfuntion with this unit with all of the same units of this model? Can someone please help me
Hello ineed sanyodmw3900 pls call me 952 215 6767
Posted on May 30, 2009
In DVD mode, Progressive Scan shows on screen. Just press the stop button on the front panel for about 5 - 10 seconds and it will go back to standard mode.
I did the same thing tonight and I just tried pressing buttons
Simon
Posted on Sep 06, 2008
THE SOUNDS GOOD BUT I ACCEDENTLY PRESSED THE PROGRESSIVE SCAN MODE AND NOW I CANT SEE THE PICTURE, I CAN HERE THE MOVIE.
PLEASE DAVISE WAHT TO DO.
txs
Posted on Apr 27, 2008
Shuts off 5-10 minutes, no 12 vdc present, fan not turning
You'r fans are still good just the board is not giving it any power. I took myne apart and blew it out with my compresser and that helped some.... But i just got a 12V wall plug in screwed a hole in the back and ran diffrent wires to it.
Oct 26, 2008 | Dual DWM-3900 System
Stuck in Progressive Mode
Had the same problem; here's what i did. Take DVD out of Receiver, close door to receiver and hold down stop button on receiver itself for five(5) seconds. changes should take effect and progressive scan screen should revert back to sanyo screen.
May 06, 2008 | Dual DWM-3900 System
Shuts down after a few minutes
have u solved the problem or still needs help, post me
Rifaa
Mar 20, 2008 | Dual DWM-3900 System
My sanyo dwm-3900 is on progressive scan mode how do i fix this
If your DVD players is set to Progressive Scan Mode, tehn ther would be a light indicating it is so. The light is labeled P?scan on the bottom right side of your display window.
You can disable/turn OFF the P/Scan mode in the "Setup menu".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
DUAL SANYO DWM-3900
I had tha same problem the fan in the back of the unit is blown I went to a local computer store and bought another fan a little bit bigger and i don't have the overheating problem any more.
Mar 09, 2008 | Dual DWM-3900 System
SANYO DWM-3000U combo dvd & vcr home theater system
I have a DWM 3000u that won't play some new DVDs. The movie is pixlated. Is there a firmware fix or do I need to buy a machine?
Lynda
Jan 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
DVD won't play: Err message
We have the same problem with our Sanyo DWM-3800.
Kal
Nov 18, 2007 | Sanyo DWM-3800 System
Dwm-3900 wont play dvd's
Because you have limited knowledge of your products history, first ensure that your Country Code is set correctly. Using your remote, access your User Menu/Setup > Country Code > U S > Memory > Setup. I am assuming that you are in the US, and are trying to view Region 1 DVD's. Please update for further instructions if the above doesn't solve your problem....good luck.
Aug 01, 2007 | Dual DWM-3900 System
Dual DWM-3900 System Logo
414 people viewed this question
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
Michial Gueffroy
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
