posted by jlizcountry on Jan 18, 2008
Do the pages go in face up or face down in the feeder to fax in a 7210 series HP all-in-one.
Solution #1
posted on Jan 18, 2008
Should go up. There is usually an indication graphic on the feed tray that shows a piece of paper with the corner folded to indicate which side goes up. Try it both ways and see which one works. Use the copy function send something through. If you get a good copy you did it right.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
AOpen XC Cube EA65-II Barebone
AOpen (95.M3919.001) (95M3919001) Barebone
AOpen 1557GL (750519117224) Barebone
ASUS ASUSTeK - TERMINATOR K7 DDR W0MODEM (TERMINATORK7DDRW0MODEM) Barebone
ASUS (r) Vintage-PE1 Barebones Desktop PC (2740994)
ASUS (T2-PH1 ID1) (T2PH1ID1) Barebone
ASUS (T3P5G965) Barebone
Can you Help with these Barebone Systems problems?
FIC IC-VG61 (dhicecube) Barebone
Case fan won't come on. pulled...
My case fan won't come on. I... Answer This...
Repair Service
Find Barebone System Repairman Near You:
