Question about Standard (CRT) Televisions
Slow channel change
Changing channels is very slow as is volume change. Entering a two digit channel provides tha second digit channel (i.e., channel 15 gets you channel 5.) Delay is 15 seconds.
  • 3130 Answers
SOURCE: channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
Posted on Mar 25, 2006
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
  • 3 Answers
SOURCE: Wharfedale LCD3210AF Television- Digital problems!
I would imagine that the Digital PCB is faulty.
Posted on Feb 12, 2008
SOURCE: Why does my RCA TV cycle through channels on its own?
Mine does the same but the volume doesnt go up.The remote doesnt work either.I am sure this is not the answer to our problem but while the tv is searching the channels be ready and puch the volume button to stop it on your channel you want and then push the menue button and place a lil peice of paper in the meue button and it will stay on
Posted on May 26, 2008
  • 52 Answers
SOURCE: mAGNAVOX mODEL 27ms3404/17 shuts down
first place to start on this chasss is with a known failure in the horizontal circuit. there is a capacitor 2455 and 2 transistors locations 7461 and 7463 that have caused a wide variety of failures. i would recommend replacing these components before proceeding as they could be the whole of the problem.
Posted on Aug 20, 2008
SOURCE: television turns on and off, turns up volume and changes channels
Usually sets that are "possessed" in this way have defective "tact" switches. Replace all switches and that should take care of the problem.
Posted on Aug 27, 2009
0 characters
1 Points
Is there a way to set the volume so i dont have to keep changing them all the time
hello, are you referring to the volume of the TV set when you change channels? to reiterate every time you change channels the volume also changes? in this case I do not want to speak too much but I'm almost certain that television providers are required to adhere to a volume leveling standard which would require television broadcast stations to broadcast at a certain volume level for unity. Are you watching cable television? I happen to know that not all cable television providers level they're broadcasting some do.I notice that you are using a CRT unit are you attempting to use a converter box with the unit? If you are using a converter box there may be a chance that volume level is one of the options in the menu, I can not say there is much at all you can do about this.
As an alternative your television set maybe damage and the volume maybe adjusting randomly or in a way other than intended.
Good luck and thanks
Questions? Just ask!
Nov 25, 2015 | Standard (CRT) Televisions
Television changing on its own
my television keeps scanning from channel 4 to channel 37 and the volume keeps going up loud and lowering by its self coule you tell me what could be wrong the television is only 1 year old thank mrs yardley
Dec 16, 2009 | RCA TruFlat 27F520T 27" TV
STB with Magnavox remote (need codes) - Samsung #TXK2766
Did extensive checking and finally found out that the remote for Magnavox TB100MW9 analog/digital converter is not made for volume control. The channel changing buttons are half-way operable--sometimes yes, sometimes no--and to think they call this a remote! Therefore you must keep the other TV ready remote that you have been using (tape them together probably) for volume and mostly channel change. I know what Magnavox can do with these remotes - and you know how much more Magnavox I will be buying in the future. Nada, none,---from a very disappointed, frustrated customer.
Feb 12, 2009 | Samsung TXG2746 27" TV
Either press menu on the Philips remote and go to autoprogram, or (if you have lost the remote), press volume - and channel - at the same time. When menu appears, use channel - to select autoprogram and volume - to select it.
-Tha Mp3 Doctor
Dec 31, 2008 | Philips TS2546C 25" TV
Sony FD Trinitron WEGA TV Model Number KD27FS170 volume problem
I had the same problem with the volume in digital mode and found the answer here:
The actual solution is towards the bottom of the post and hard to read through, so I simplified the instructions below:
On your remote control (with tv off)
1. press Display, channel 5, Volume Up and then Power
this brings up the service mode (you will see some green text on your screen)
2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen
(channel 2 cycles up through the options, channel 5 cycles down)
3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro"
(channel 1 cycles up through the suboptions, channel 4 cycles down)
4. Press channel six until the default value (12:60) changes to 12:40
(channel 3 increases the value, channel 6 decreases the value)
5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write"
6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
Nov 22, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Channel changing randomly
the channel switch button had a contact to each other... or clean it...
May 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Standard (CRT) Televisions
re- program...................................................
Jan 25, 2008 | RCA F32450 32" TV
Try unplugging the set for a couple of minutes then plug it back in.
Nov 01, 2007 | Sony KV-32FS13 TV
TV turns on and changes channels on its own
Keeps changing channel
Check voltage on D12 if below 4.8V then change
Changes channel or volume adjusts by itself
Check S900/1/2 on pcb H1, alternatively this could be due to failure of IC005 (CD4052BCM-FL63) on pcb A
Oct 17, 2007 | GE 31GT740 31" TV
Standard (CRT) Televisions Logo
576 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
