Question about Liquid Video E15LCD1 15"
No Signal When I plug the monitor in my laptop recognizes the monitor and tells me it is hardware that is enabled. The monitor has a green light, a little sign pops up that says "No Signal" and then the screen goes black and the light turns amber. Nothing else happens. The screen stays black and the monitor is on stand by no matter what I try to do.
  • 589 Answers
You have to use the FN key and F5 to change between the LCD screen and the external monitor. It may be F8 also, depending on the laptop model.
Look on the F keys for a little picture of a monitor.
Once you have found it, hold the FN key and tap the F key and it should switch to the external monitor.
Posted on Jan 18, 2008
  • brian c
    brian c Jan 18, 2008
    I forgot to add, the FN key is somewhere down on the lower left of your keyboard.
DS240WB worked fine but seems now not recognizing signal and fails to turn on
The reason why your monitor might not be recognizing a signal is because the graphics card in your pc might not be correctly plugged into a pci slot or your internal graphics may have a short somewhere. If the monitor turns completely off after it cycles Then it might be an internal problem with the backlighting in your monitor screen
Dec 07, 2013 | DoubleSight DS-240WB Monitor
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
Red light on computer monitor, black screen, but nothing else
if the power indicator light from green then turn to red with no display, check the power supply board which may have leak or bulged capacitors. check also weather your vga cable is good, if no signal the monitor will turn to off.
Oct 14, 2012 | Computers & Internet
Monitor says no input signal going in sleep mode
TRY UNPLUGGING COMPUTER AND MONITOR AND DISCONNECTING MONITOR FROM THE BACK OF THE COMPUTER. BE SURE TO UNPLUG AND NOT TURN OFF. WAIT ONE MINUTE THEN PLUG COMPUTER BACK IN . RECONNECT MONITOR TO THE BACK OF THE COMPUTER AND PLUG IN. IF THIS WORKS, WAIT FOR NEW HARDWARE RECOGNIZED TO COME ON. FOLLOW INSTRUCTIONS, IF ANY. RESTART COMPUTER.
Feb 08, 2010 | HP vs15 15"LCD Flat Panel Monitor
Viewsonic monitor lcd to laptop problem
Remove the second monitor entry in Device Manager, and let the machine try to find the driver. I swear, sometimes, computers have minds of their own! ??
Apr 04, 2017 | Computers & Internet
Usb port refuses to recognize plug in hardwares,
You can check from the Device Manager and see if you can enable it from there. Right click on your My Computer and choose Manage. On the left panel click on Device Manager. From your right, expand the Universal Serial Bus controllers. Right click on each on the list and choose Enable.
Also so you can go and check on your BIOS settings and see if the USB port is enabled.
Goodluck and hope this helps.
Oct 27, 2009 | Acer Computers & Internet
Emachine T2672 will not recognize monitor
First, check to see if the computer is actually running--look for the lights on the front and listen for the fan (also, put your hand behind the machine to see if you feel air coming out). Once you determine that the computer is actually running, look at the monitor. Is it on? Is there a green or yellow light? If not, be absolutely sure it's plugged in both to the monitor and to the computer and the power source.
If you have a yellow light and the computer is running, it might be the video card. If there is not yellow or green light, the monitor is bad.
Find a friend who has a monitor and borrow it. Plug it into your system and see if it works. If so, the problem is your monitor. If not, then the problem lies in the computer.
Jan 26, 2009 | E-Machines eMachines Monitor E15T4
NEC MultiSync FE2111SB 22in monitor problem
a blinking green light usually indicates no video signal. check your cables, and if you have another computer, try it on that. otherwise, carefully check your vga signal cable, and the connections on the neck board [where the crt plugs into]
Aug 11, 2008 | NEC MultiSync FE2111SB 22" CRT Monitor
Is it my monitor or my video card
1.there might be a problem with your signal cable. if one of the pin in the signal cable is open. it might also happens
2.adjust signal cable.
3.Check VGA video card is working properly. unplug the VGA card and Re-plug to its slot. if your mother borad has inbuilt video card. this process cannot be performed
4.Even problem with operating system might also happen.. problem with Video Ram memory
5.if you want to check whether your monitor is ok. just get Cpu Box alone frm friends for a while for a testing.
6. if your monitor have problem then contact service centre.
Oct 15, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Liquid Video E15LCD1 15" Logo
169 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Mark Gough
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
