Question about Motorola Mobility C290 Cellular Phone
Charging battery when i try to charge my phone c290 the hellomoto screen comes on the goes right back off and back on and that is all it will do. Is it charging or is something wrong?
    Problem Solver:
  • 16 Answers
If it just turns on and then off again, and then nothing happens, and if you have full battery capasity when you've been charging for a while, you are charging your phone, and nothing is wrong.. it's just a process when you put the charger in your phone...
Posted on Feb 08, 2008
6ya staff
SOURCE:
My phone has turned itself off,& won't turn back on, whether it is plugged in or not. Any idea why?
sounds like you need a new phone but id take it to a where ya bought it and see if a different battery fix's problem. ive had a battery that would discharge all its juice at random and had that burn up a motorola. hope this helps
Oct 26, 2012 | net10.com
Phone turns on and off but wont start
try using ur phone while plugged in charging. if it works thn ur battery defective
Aug 05, 2009 | Nokia 6500 Classic Cellular Phone
New phone won't turn on just has "Hellomoto" screen
hi.there...don't worry.. what happens with your new cellphone..is normal..why? when your battery is low and there a pop up screen at the display "battery low...please recharge" that's mean you must charge the battery soon.
when connect your phone to charger adapter and your battery is very low / weak condition the display only showing "hellomotto" and nothing else. but it's normal! diplay need more power from you battery to showing all information.after the battery reach the minimum power to display it ( usually after 15-20' charging) try to push red bottom at your keypad phone and the display will showing again..good luck..
Feb 02, 2009 | Motorola Mobility RAZR V3
Locked up at the "Hellomoto" screen
all - the firmware on the phone needs to be reflash to correct this issue take the phone to a mobile service center to have this done.....
GUEST -
take the phone to a mobile service center to be unlocked or try online at unlocknow or mobile2mobile.net
Dec 12, 2008 | Motorola Mobility RAZR V3
Bootloader USB INIT
Reflashing the phone requires that you have acces to some service software programs (PST for example) and a correct, unlocked, stock flash+flex pack, also compatible with your bootloader version. As a general rule of thumb, if you don't know what this terms mean i recomand you try to avoid the process. Some people ended up with bricked (dead) phones because they simply didn't had some field experience with flashing phones or service and bootloader commands. My advice would be to play it safe and try to get help from a service center.
Jun 19, 2008 | Motorola Mobility C290 Cellular Phone
Phone problem. Phone will turn on but...
Hangs on "Hellomoto"
Motorola Software Update (MSU) located on the Motorola website:
http://direct.motorola.com/hellomoto/Motosupport/source/SoftwareUpdateSelect.asp
This should upgrade your phone’s software and restore functionality of the phone.
May 22, 2008 | Motorola Mobility RAZR V3
Phone wont turn on passed "hellomoto"
if it's a boost phone and isn't overly damaged cosmetically, they will replace it as a defect. 1-877-TLK-MORE
Dec 11, 2007 | Motorola Mobility C290 Cellular Phone
Screen stuck on hellomoto
Hi try pulling out the battery for a few min and later when you put back the battery , keep your phone for charging. Then try switching off and off when the charging is taking place. Hopefully it should solve the problem.
Oct 20, 2007 | Motorola Mobility MING A1200
Motorola Mobility C290 Cellular Phone Logo
61 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
