Question about Hitachi 57S715 57" Rear Projection HDTV
Help Noticed the other day the picture was very dark and could not see any detail in the picture. Ran Magic Focus and all colors (Red, Green , and Blue) showed up fine. Hitachi told me to unplug to reset the TV. After unplugging and letting sit for an hour I plugged back in and the TV would not even turn on. Tried unplugging and plugging in numerous times and still would not turn on. There are no lights that come on at all. Any ideas on what is wrong and how much it will cost to fix?
  • 2 more comments
  • dbviking Jan 18, 2008
    Would the blown fuse cause the picture quality to be poor before I unplugged it?
    Would the picture quality be poor and dark before I unplugged it with a bad fuse?
    How hard is it to check and replace the fuse?
  • dbviking Jan 21, 2008
    I got the TV to turn back on now. Thanks for the help.
    The picture is still terrible. Everything is kind of blended together, it is really dark, and it looks like not all of the colors are showing up when I watch TV. All 3 bulbs are still fine as when I run the Magic Focus Red, Green and Blue all show up. Any ideas on what could be causing this?
  • dbviking Jan 22, 2008
    I had a repair man look at my TV and he tapped on the CRT boards and the picture became clear again and looks perfect. He said the CRT boards are going out and would cost $500 to repair. Does this sound reasonable?
    Also, I unplugged the set and replugged it in and it would not turn on again. I have had this problem previously. Could that have something to do with the CRT boards going bad and not resetting properly when unplugged?
  • 4,402 Answers
Sounds like a blown fuse in the power supply
Posted on Jan 18, 2008
  • 1 more comment
  • Cary Farah
    Cary Farah Jan 18, 2008
    i think you blew the fuse when you tried to plug it back in, open the back and follow the power cord and it should be close to where the cord enters the tv, it should be a glass fuse that snaps out, you just snap a new on back in, might be able to pick one uup and radio shack., lets get the set going first before we worry about the other problem
  • Cary Farah
    Cary Farah Jan 21, 2008
  • Cary Farah
    Cary Farah Jan 23, 2008
    here's a link to a crt fix it's for a Toshiba but your should be simulator and should give you some hints as to what to look for
I think that it is the green because i did what you said and it is still there. there is a feature on my tv called magic focus it brings up the colors and the blue and the red are very focused but the...
This tv is a DLP projection tv right?Magic focus button push don't solved the focus picture problems,have colors shadows or 3D pictures problems?The tv have a problems known as a convergence problems,it dead.The tv convergence board.Must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved the tv picture convergence problems.The shop,will cost u $300-$350 for parts and labors.
Oct 02, 2010 | Televison & Video
Colors are out of focus and magic focus wont fix
If you have tried the customer convergence menu/control and can not set the convergence you have a fault with the electronic circuit that controls the convergence of your 3 picture tubes this overlaps the 3 colors red, green, blue to create the proper color combination's of colors for a proper picture
May 05, 2010 | Hitachi 57F500 57" Rear Projection...
Hitachi 61SDX01B Dark Picture and bad color
There isn't anything you can do yourself for this problem, but it should be worth having a qualified technician look at it.
Sep 09, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Feb 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Jan 27, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Loss of color picture
I have a blue-ish yellow ghost tint which just appeared on my 51" 51SWX20B made July 2002. Did the magic focus got a number 5 at the end. Did you get a number when you did the magic focus?
Dec 01, 2007 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 61SDX picture got dim shows Code 3
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 17, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Faded colors
If the picture is dark or messed up too bad, the magic focus will not function, are all the primary colors faded? RED GREEN BLUE? You might have a bad CRT, would call a service man to check out.
May 21, 2007 | Samsung HCN5527W 55" Rear Projection...
Bad picture
convergance ic bad
Oct 26, 2006 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi 57S715 57" Rear Projection HDTV Logo
184 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
