Question about Panasonic Lumix DMC-FZ50K Digital Camera
Play on LCD
In the setup menu the item "play on LCD" the lettering is very dim and I cannot scroll to it with high lighter to turn it on. Why? I can to the others in the set up menu and set the option.
  • 95 Answers
SOME MENU FUNCTIONS WILL NOT ALLOW YOU TO ADJUST THEM BECAUSE OF ANOTHER SETTING THAT HAS A HOLD ON THAT FUNCTION. I SUGGEST YOU FIRST CHANGE THE MODE AND THEN SEE IF YOU CAN SET THAT FUNCTION. IF YOU CANT THEN DO A PARAMETER RESET THEN TRY.
Posted on May 27, 2008
How do I set up the answering system on the Vtech?
Try this:
press [menu]
scroll to "Answering Sys"
press [select]
scroll to "Ans Sys Setup"
press [select]
--- ( begin the setup item list )---
==1== as you scroll to each item to be set up,
press [select] to address that item
scroll through that item's choices,
then press [select] to confirm the choice selection
(chirps) and returns to the setup item list
==2==scroll to the next item
==3==scroll to the next item
==4== etc.
when finished, press [OFF] a few times to back up to "Handset #"
Feb 22, 2016 | Vtech CS6629-3 Silver Cordless Phone DECT,...
When i start my joybee 110 the backlight switch off in feww seconds and the language has turned to chinies by mistake now i want to change the language to english .
Press MENU button then choose System Setup. This is the one before the last item in the menu. Then scroll down to the one before the last possibility. This should be the language. To choose this press PLAY/PAUSE button and you can see 3 languages and the last one is the English.
Now simply press PLAY/PAUSE when you are one the last position.
I hope this helps.
Thanks.
gylacz
Sep 02, 2011 | BenQ Joybee 110 MP3 Player
I cannot figure out how to get it to play more than the 1st movie on some multi movie DVDs. Help!
Press the top menu button on the remote after putting a multi movie DVD. Scroll down on the movie file you want to play and press enter. You will see two items in each of the movie folder, Scroll down on the second item and press enter.That is the movie folder. It will play.
Mar 08, 2011 | Sylvania DV220SL8 DVD Player/VCR
I cannot play burned dvd's from this system in other dvd players becahse I cannot finalize the dvd. How do I finalize?
The recording may have used all the media on the disk because you let it run until it was full.
Now, there is no room to finalize the disk.
Play this back on the machine where it was recorded while recording it to another DVD recorder..
This time, BE THERE to stop the recording.
Set the recorder to a speed that leaves at least 10 minutes extra space for finalization.
Jan 31, 2011 | Pioneer DVR-RT500 DVD Recorder/VCR
The store demo mode is stuck on my insignia tv. the user guide says go to menu and then setup and select plug & play. however the plug and play option is grey and it wont let me select it.
Are you using an HDMI cable? Go to input and select TV. Then you should be able to access the Plug & Play option and be able to turn off the Demo Mode.
Jan 03, 2011 | Insignia 42" Flat-Panel Plasma HDTV
I am trying to get audio to play through zone 2. I have a CD player connected to AV 5 input on the receiver. When I switch to zone two, I am able to select a source, AV 5, when I attempt to turn the volume...
* Get to the receiver setup menu by pressing the "On Screen" button on the receiver's remote control. * Navigate the menu to "Setup". * Then scroll horizontally to "Multi Zone". * Select "Zone2 Set".
** If the menu items are grayed out here (if not skip below) ** * Go back to the horizontal menu (where you selected "Multi Zone" * Scroll to the "Speakers" option * Make sure the "Power Amp Assign" setting is correct (allowing for multi-zone).
*** In Zone2 Set *** * Change the range, default volume, and increments as desired.
I hope this helps! Mike
Dec 24, 2010 | Yamaha RXV667 Receiver
Sony CDX-S2210 CD Player stuck on demo mode , cant adjust volume eq, skip track or anything
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Jan 28, 2010 | Sony CDX-S2210 CD Player
Scrolling
just hit the main menu botton twice it will automaticly play all for you.
Jun 20, 2009 | GE JASRM24912 Remote Control
Sony bravia dims randomly
There should be a setting in the menu of the TV to turn off the auto dim feature (used for adjusting the brightness of the picture depending on ambient room lighting) I don't have a Sony LCD here with me to walk you through the menu settings, but I am certain it is there somewhere. (Chased this issue for the wife who had the same displeasure you're having)
May 04, 2009 | Televison & Video
AMW DVD Player
my dvd doesnot play ,power is on screen is ok.but the dvd did not play (no rotation of the disk)
Feb 14, 2008 | Amphion Mediaworks M-270 Portable DVD...
Panasonic Lumix  DMC-FZ50K Digital Camera Logo
21 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
