Question about Maytag Legacy Top Load Washer
Maytag SAV 205 DAWW
The washer stops for no reason, 20 to 30 min later it will start. Rotaed the timer to other positions, As soon as I went to get my meter to start trouble shooting the washer started. This has hapen 2 times so far. Did ohm out the door saftey switch seems fine. What other saftey are there that would hold it out. Or I am I looking at a possible intermitted timer select switch?
Thanks
  • 2 more comments
  • no free time Jan 18, 2008
    Will take the shop vac to it on Sat. Did not think about the internal OL. Would not the timmer keep on running? Or are they some how electrical /mechanical interlocked?
  • no free time Jan 19, 2008
    Thanks, will work on it Sat. Will put the amp probe on it and compare the reading to the name plate. At what cycle is the largest draw on the motor? I was looking for a wiring diagram in the top pannel. Did not find one. I am curious on how they interlock the motor running to the mechanical timmer motor. The timer motor must then be in series with the motor over load ,
    Removed the bottom cover to expose the motor compartment, Was very clean, no lint build up any where. Just a little belt dust that looked normal for a 3 plus year old unit. The motor amp rating is 8.7 / 7.4 (two speed motor) I measured a constant 6.2 amps , lower on spin. The motor over load is very visible , I did disconect the wire on the overload and it does duplicate the same problem. Possible faulty over load. Question: can the over load be replaced? The motor looks like a pain too remove or worst case run it with out the over load, But I do not like to operate electrical eqipment with out protection.
    I do agree the overload could be faulty. Looking on line, there is not a part # for a motor overload, they sell a new motor only, do you know if that is sold by it's self?
    Thanks for your help also!
Washer stopped and I was able to get my meter this time. Found no voltage to the Motor Overload and door saftey switch. Ohm them out, closed. There was line voltage going to the the timer(120 vac) I then checked to see if there was voltage at any of the other pins. No voltage. Taped the timer a couple of times and you could then hear the timer motor start running, Then washer finished it cycle. I bought a new timer and it has been find. The tough ones are the ones when they are running when you get the meter.
Posted on Jan 24, 2008
  • 38 Answers
Look for a self resetting overload on the motor. many motors have an overload that pops a little red button out and waits for a push to reset. Other overloads will reset automatically because they are hard to access for pushing a button. If there is an overload resulting in a shutdown you will have to determine the cause. I have found motors in washers completely ingulfed in dust and lint (from the adjacent dryer) and not being allowed to dissipate heat. Sometimes a thorough cleaning is all that it needs to run cool and efficiently.
Posted on Jan 18, 2008
  • 1 more comment
  • Anonymous Jan 19, 2008
    It would make sense for the timer to be after an automatic overload so that the cycle can continue where it left off. If it continued to run it would finish and you would have a tub full of water or unwashed clothes. If you look at incoming power before it seperates from the motor to the controller you should find the culprit. Does your meter measure AC amps? You might want to get a fix on the current draw of the motor to see if it is in fact overloading. Let me know how it goes.
    Almost certainly the largest draw will be during the wash cycle when the motor has to run the agitator. measure over time and see if amperage increases. I am not 100% convinced but do suspect a heating problem with the motor. The current should follow a curve and get worse as it gets hot. Throw a thermocouple, O-scope and chart recorder on it too then we will really know, kidding unless you actually have the equipment.
    You could put an inline fuse just to see if it ever doe overload. Go 125% of Full load amps round up to next standard fuse size if it pops your overload was doing ist job. If it does not pop replace the overload. You might also consider running a cycle without but if you do that make sure it is on a 15A breaker not a twenty and keep a close eye on it. If you have a meter with a temp probe put it on the motor and watch that also..I suspect you just have a nusiance overload.
6ya staff
SOURCE:
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Maytag centennial washer - power went out while washer was operating. When power was restored the washer does not cycle. I have to turn it manually through the cycles.
Set the timer to any off position. Unplug the unit for 10 minutes. Plug it back in and try that. The worst thing
you can do to a Maytag washer is advance the timer yourself...hope this helps.
Apr 02, 2011 | Maytag Centennial MTW5800TW Top Load...
My maytag mav6200aww washer stops at the rinse or the spin cycle. However, if I wait about 30 min it will work. Possibly a bad timer? Are they difficult to replace?
If the washer is working properly in the wash cycle & not the rinse or spin cycle, I would suspect a defective timer especially with the delay of 30 mins you described. Replace the timer with this part.
Jan 14, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Dewalt Pressure washer keeps shutting off for no reason. plenty of gas and oil, water running to it. starts fine and as soon as I start spraying it shuts down.
Had a similar issue with my dewalt 4200 pw. Unit starting shutting off after spraying for about 5 min. Then difficult to restart, but would start again eventually only to shut down a few min later. Had new engine oil, new pump oil, good gas. I changed the spark plug and unit runs great again!
Aug 08, 2010 | Dewalt 3800 PSI Pressure Washer
My washing machine has a mind of its own, it starts ok then stops....then I have to push in starting botton,,,,then turn it on maybe 10 t0 15 min later the works again and it stops I have to turn on and...
You are correct in guessing the timer. The tongs are stripped out and the best way to prevent this in the future, once you have installed a new one, is to turn the timer around clockwise - ONLY - and very slowly and gently. Your machine will last much longer. This is the case on all your electronic appliances.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and will get the correct part out to you asap.
We look forward to working with you and hope this solves your issue.
You may contact us from 7 AM until 9 PM CST Monday through Saturday.
Thanks, Ella
Nov 09, 2009 | Magic Chef CAV2005A Top Load Washer
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag SAV 2655 AWW prblems?
take a look at epinions.com for this model
seems almost everyone's had problems with it
Nov 17, 2007 | Maytag SAV2655A Top Load Washer
Washing Machines Logo
831 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
