posted by cheeto1547 on Jan 18, 2008
installing power swupply e machine T 3624
Comment by cheeto1547, posted on Jan 26, 2008
old power supply was removed new almost fit taped wher plugs went while awaiting new e mach. P.Supply tape came off do not know where to plug any thing in Thank YOU !
Solution #1
posted on Jan 25, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Not sure what you requesting as information but to install a power supply is easy (make sure it's not plugged in obviously). Take off the case...it's right there. Unscrew from the outside to remove and install new. One word of caution...I am not a big fan of E-Machines "past"....motherboards and power supplies were (are?) major failure items with these machines. If you wish to know what supply to use check what you have and then go to pricewatch.com to find one....note, it need not be the same brand (preferable probably) but it does need to have the same dimensions and wattage. Trust this helps...Tango
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Suggest a new solution for this problem
Post a New problem for E-Machines E-Machine Power Supply
Email this problem
Email this problem
Can you Help with these System Power Supplies problems?
power supply pinouts for nec...
Hello' Please, I need help with... Answer This...
Repair Service
Find System Power Sup. Repairman Near You:
