Question about SanDisk Sansa e250 MP3 Player
Got wet. Powers up.
Get "Rockbox bootloader VXXXX
Can't find partition" message
Have it in recovery mode now. Just want to wipe it clean and start from factory state again. How?
  • 226 Answers
Re: got wet. Powers up.
I suggest that you should reformat mp3 player it might contain viruses, and other malicious programs. After reformat your mp3 player will be as good as new.
connect your mp3 to the computer, right click on the drive then click format.
Posted on Jan 21, 2008
0 characters
3 Points
What does it mean when android robot is laying on its back
I am giving you an example with an Motorola Tablet. I'd try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
As you're going through the options don't do the factory data reset, look for wipe cache partition then follow the instructions to reboot.
Hope this helps!!! Let me know if you need more help
Dec 25, 2012 | Ematic 7" eglide Pro Tablet
Black screen that just says "load main image failed Switch to recovery mode"
okay have u tried going in recovery mode, (push power and hold at same time) may it will boot the whole system, if not look out for ROCKBOX ( foe new operating system
Dec 10, 2009 | SanDisk Sansa e250 MP3 Player
Removing partially loaded Rockbox & Wiping Clean mp3 player
connect san tp pc....go to my computer, click on san icon (you are going to copy the san software and hidden files also to pc) you can also copy your music if not already on pc....once you copy san's software and hidden files not rockbox to a folder on the pc.....format san (this as you know will erase all of the hard drive of the san) say yes............once format is complete reinstall san software (and hidden files this is a must) now you just renew your san (a new beginning)........have fun
Apr 29, 2009 | SanDisk Sansa E280 MP3 Player
Cannot install rockbox on my sansa e250
did you extract rockbox...........did you patch it you need this also (DOWNLOAD THIS FROM HERE)
once you do this plug device to pc...copy what was extracted and paste to root of the device
installation link
have fun rock with the box
Feb 03, 2009 | SanDisk Sansa e250 MP3 Player
Problems with Sansa e250 + Rockbox
Go to Sandisk's website and download the Sansa Recovery Tool
Jul 04, 2008 | SanDisk Sansa e260 MP3 Player
Windows Recovery Mode:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 14, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 problem with Rockbox
Get the Sansa Recovery Tool from the Sansa website.
1 - since you really did nt delete all of rockbox (you shoud reinstall the whole thing) this will take of the system looking for it.
2 - you will have a dual boot up and a choice of which one u wish
Key Action
Power Start Rockbox
Long Power Shutdown Rockbox
On shutdown, Rockbox automatically saves its settings.
Rockbox has a dual-boot feature. To boot into the original firmware, press and hold the Left button while turning on the player.
feel free to rate the help
Sep 23, 2007 | SanDisk Sansa e250 MP3 Player
Rockbox Firmware not installing after recovery mode on player
The firmware instal intructions quite clearly tell you NOT to attempt to instal Rockbox in recovery mode. You must have it in MSC mode.
Aug 02, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
