Question about GE JGBS23 Gas Kitchen Range
Swooshing sound in oven when burner ignites
When the oven lights, there is a swooshing sound while the burner is ignited. The valve that lets gas into the burner, lets gas in whether the burner is on or not. Where the air shutter, is a flame will appear, and stay even after the oven is turned off. The valve has two wires on it and one reads 115VAC even when oven is off. The swooshing noise is only when burner is ignited and flame is present in the air shutter.
Thanks.
Ron
    Champion:
  • 202 Answers
Very good Robert She may get blown up Thanks
Posted on Sep 24, 2011
This is a common issue if the flame runner is not working properly. The ignitor is probably working fine. The flame runner directs gas into the ignitor where it ignites. the flame is then "run" down the burner causing all of the gas to ignite upon exiting the burner tube. When the flame runner cracks or gets dammaged, the flame is not run efficiently down the burner and gas is allowed to exit out of the burner holes without being ignited. This also may prevent the flame frome reaching both sides of teh burner. This gas builds up until it contacts a flame then it ignites violently. This can also be caused by a plugged hole in the burner near the ignitor. Best advice is to verify this is the issue and replace the burner. While this event can happen indefinately without an issue...it can also lead to a potential explosion in the oven. Also, your oven probably does not control heat very well while this is happening. It can also reek havoc on a birthday cake.
Posted on Dec 07, 2008
    President:
  • 1,314 Answers
The valve your talking about with the two wires on it is the safety valve and should not let gas in without the ignightor being on sounds like its leaking i recommend shutting the gas off till the valve is replaced there is no piolet light on theese ranges
Posted on Jan 18, 2008
My stove lights very slow with a low flame. Should the igniter stay on after it lights oven
Yes the ignitor stays on even after the burner is lit. The ignitor is wired in series with the oven valve. It sounds like the oven valve isn't opening all the way. A new ignitor should solve this problem. The old igniter builds up resistance and doesn't let the correct voltage through to the oven valve for it to open properly.
Tom
Aug 16, 2010 | Magic Chef CGR3725 Gas Kitchen Range
My oven takes a long time to light and there is a strong smell of gas..why?
This can be caused by a weak/inop hot surface igniter ,defective gas control valve or debris in the burner orfice/venturri. The gas odor is going to be caused by unburned gas due to a by-passing gas control valve or a weak igniter(not lighting the gas coming from burner) First you will need to verify that the hot surface igniter is coming on(you should see it glow in the burner compartment). If it is not glowing then you will need to verify that the wiring harness has voltage to it when the oven thermostat is on. Also check the igniter for any cracks or damage and if found then replace the igniter. If it is glowing then one thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the by-passing problem. If the oven burner comes on when tapping the valve then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad. Also inspect the burner venturii and burner orfice for any possible debris(grease,lint ect) that could be restricting gas flow. One more thing you can try is to manually light the burner. Make sure the oven and burner compartment are COMPLETELY cleared out of gas. Then make sure there is a flame from a match or lighter right next to the burner where the igniter is located(it is best to use a long fireplace match) before starting oven. Once the flame is lit and next to the burner then turn on the oven thermostat and listen for the flow of gas. Once the flow has started the oven burner should light immediately! If the burner does not light within 2 seconds the remove the flame and shut down the oven. If the burner lights with the match then either the igniter is not hot enough to light the burner or there might be a restriction in the burner head blocking the flow of gas to the hot surface igniter...or a restriction in the venturri or orfice. You will need to be extremely careful performing these procedures! If you are smelling gas then the oven and burner compartment could fill up with enough gas to cause a delayed ignition! You could get burned or seriously injured so I advise you not to try these procedures if you are not experienced with gas appliances. You are taking your own risk trying these procedures and if you feel uncomfortable trying these then I suggest call a professional.
Apr 17, 2010 | Tappan TGF363 Gas Kitchen Range
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Oven will not light
    When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
    If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
    A faulty igniter is probably the most common cause, however there are others:
    -- defective thermostat
    -- defective selector switch
    -- defective gas safety valve
    -- defective gas valve coils
    Oct 16, 2009 | Magic Chef 31000 Gas Kitchen Range
    Oven wont light
    -- defective gas valve coils(This will be the next possible issue if the igniter is functional)
    Sep 26, 2009 | Frigidaire Ovens
    The gas oven will not light. gas burners light but oven does not
    O-defective thermostat
    O-defective selector switch
    O-defective gas safety valve
    O-defective gas valve coils
    Sep 20, 2009 | Ovens
    My Amana gas oven won't heat up gas smell strong
    Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
    Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
    How do you light the oven? We turn the dial and
    I take it the range is electric ignition because you say the top burners have a clicking(igniter) noise. If the top burners are electric ignition then the oven is also. The oven probably uses a hot surface igniter and that is why you do not hear any clicking. Turn the oven on and open the broiler compartment. You should see a bright glow from the hot surface igniter. If you do not see any glow there may be a grounding issue or the igniter could be bad. If you do see a glow but the burner does not come on in a few minutes then give the gas valve a tap with a wrench and see if the burner comes on. Shut it off and then back on several times. If the burner continues to light after this you may have fixed the problem. If it does not come on gas valve could be sticking or igniter is weak.
    Sep 10, 2009 | Magic Chef 31000 Gas Kitchen Range
    Burner not lighting but igniter is glowing red hot.
    The flame sensor is not activating the gas valve. Check or change sensor.
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
    Jul 22, 2009 | Maytag CWG3100A Gas Single Oven
    Oven won't light, even with ignitor getting red
    If your oven won't bake, check these:
    Bake igniter
    Other causes
    Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
    The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
    Other causes Other reasons that your oven may not bake are:
    • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
    • The thermostat is defective.
    • The safety valve that prevents accidental gas flow is defective.
    • The selector switch is defective.
    May 23, 2009 | Magic Chef 9122 Gas Single Oven
    GE JGBS23 Gas Kitchen Range Logo
    253 people viewed this question
    Top Kitchen Ranges Experts
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Sal De
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
