Question about Antec TruePower Trio 550 (TP3550) 550-Watt Power Supply
Pc wont turn on
When pc switched on key board lights flash once, optical mouse light comes on,but pc does not power up. tried different psu (new one) and tried bypassing on/off switch.any other ideas please
  • howie p Jan 18, 2008
    still no change. power light not coming on or fans, or much else apart from mouse light
    no beep, moniter in sleep mode (blank screen, flashing green light)
    Genius:
  • 1,665 Answers
Do you read something at your monitor when pc starts?
can you open Bios setup pressing DEL ?
If you dont see anything on the screen perhaps there is faulty graphics card or display monitor.
do you hear any beep-beep when push power on?
observe and describe what happens when pc starts.
Posted on Jan 18, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jan 18, 2008
    make sure your graphics card is well fitted in the slot and monitor data cable connected to the card.
    Also check all cables from PSU to motherboard to connected correct.(unplug- plug again)
    if is posible to check that monitor is ok connected to another pc would help . the same for the graphics card.
    Was this pc working before or just try to assemble it?
    President:
  • 4,402 Answers
Removed hard drive, floppys , extra memory all pc cards
everything you can and try it again
  • Cary Farah
    Cary Farah Jan 18, 2008
    you have a bad power supply
Gateway dx 4320 wont turn on
It could be a few things:
a faulty power switch - you say that you've changed the PSU, but did that include the switch?
it could also be a Faulty Motherboard or CPU. If either of them are fried, you won't see anything come on either.
I'd suggest checking the switch first because that's the cheapest and easiest to replace
Sep 14, 2012 | Gateway DX432019 PC Desktop
Flashing red power light on Gateway 700X
try disconnecting the lower optical drive and rebooting...may just be a bad drive.
Sep 04, 2012 | Gateway 700 X PC Desktop
Compaq nx6110 PC Laptops: When i turn it on the lights flashes then goes off...
Which light flashes? If it is the battery light then perhaps your battery is empty?
When plugged into your PSU does the power light turn on? If not your PSU may have broken or the plugs fuse may have blown.
Other potential causes could be your RAM, CPU or even your system board. Check the RAM is correctly seated, if two modules are installed try removing one.
Hope this helps, www.PuterCare.com
May 17, 2010 | HP Compaq nx6110 PC Laptop
Flashing green light on psu
you need a new power supply and try it see if any change it try to take off your modem and one of the 2 will be a problem thanks
Nov 08, 2009 | Computers & Internet
Emachine D2880 no power clarification
your getting power to your PSU, via the green light on your mobo.
verify the PSU has a green light(most emachines do)
it sort of sounds stupid but, check the connection of the cable coming from the front of the case(the wires that connect to the mobo to the power button on the outside of the case.
if all else fails, take the pc out of the case.. put all components on a static free bag and start to rebuild your PC(without a case)
...this will rule out a short on the PC case, and faulty wiring from the case...
pretty much sounds like you've been through almost every step except replacing the PSU(you just said you tested/but your getting power to the PSU)
hope some of this helped
Sep 04, 2009 | E-Machines eMachines Desktop PC
Power light goes out but power remains thru the m-board fan runs
you need to replace the power supply. The fan sound is the fan for the power supply and not the computer. for cheap parts or used goto headgap's. They know what you need and probably even help you replace it yourself.
Jul 03, 2009 | Computers & Internet
Key board and optical mouse - PS2
muito simples:faz o download dos drives do teclado e rato da versão superior á que tens.depois vais ao painel de control+sistema+hardware,e fazes a actualização dos controladores.
VERY IMPORTANT:COPY ALL DRIVES TO DESKTOP.
copia para uma pasta,criada por ti no ambiente de trabalho,com 2 pastas 1 de keybord-1 de rato,copia entao os drives das duas versoes do equipamento,para essas pastas,
ao iniciares a actualização dos controladores ,indica sempre a pasta com os drives respectivos.
BOA SORTE
ALLIENFENIX@HOTMAIL.COM
Sep 11, 2008 | Computers & Internet
Wont post.
Try a few things for me OK? From what you typed, turned on the psu "the toggle switch on the psu", pc seemed to be starting up. I need you to keep the toggle switch on the power supply in the on position. Press and hold the start button on the PC case to shut it down. Give it a few seconds & power up by pressing the power switch on the case. Notice a differance? Next, unplug everything connected to the pc expect the monitor, mouse & keyboard. Try to boot. Still no? Remove the side of the case exposing the board. Turn the psu off by flipping the toggle switch on the psu, wait till the green light on the board goes out. Grab the Mb ( I know it's tight in there) and see if you can move the board in any direction. Not loose? Re-check all data & power connections for a solid connect. Re-check your case to Mb connections. Also check the PSU, there is a red slide switch it should be set to 115v. Post your findings..
map
Jan 28, 2008 | ASUS P5ND2-SLI Deluxe Motherboard
Desktop pc e machine 4210
Can U get to the bios? (F2 at power on logo) Check the settings and set to default settings.
Dec 08, 2007 | Computers & Internet
Acer Aspire 5633WLMi Laptop
unplug everything that isn't necessary to run the laptop ie, external mouse, battery, etc. Then plug the ac adapter in, making sure the switch for 110/220 is appropriate for your region. Now, does the machine turn on? PLease respond with the answer, and we'll go from there. Good luck
Sep 04, 2007 | Acer Aspire 5600 Series 5630-6951 Laptop
Antec TruePower Trio 550 (TP3550) 550-Watt Power Supply Logo
156 people viewed this question
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Dimitar Todorov
Wahs Team
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
