Question about Dryers
Maytag dryer LDE5004ACW not drying
First the blower fan was not turning on the shaft, fixed that problem. Turned dryer on last night, it was still running this morning and it is not making any heat. Vent and filter is clean and no blockages.
  • wasat Feb 13, 2008
    found one wire to temp.sensor burned in half. Replaced wire. Dryer works great.
  • 109 Answers
SOURCE: maytag performa intellidry dryer model#PYE4500AYW
Check drive belts. If too loose or too worn it will not spin at proper speed.
Posted on Mar 27, 2009
SolutionGuy
  • 331 Answers
SOURCE: dryer takes too long to dry
You have an airflow restriction and it's most likely in the vent inside the wall leading outside. I know this because the dryer is trying to do its' job (and that the default "fail" mode on the t'stats is "open". That is to say... if a t'stat fails, the dryer won't heat).
The only other thing that causes an overheat condition is a failed blower assy. When these fail, though, the dryer makes an awful racket. And since you didn't mention an awful racket, I go with clogged vent pipes in the walls.
When my customers call who have the same symptoms as you, I don't even bother running the service call (costs me money, but I'm an honest guy). I recommend they call a dryer vent service or a chimney sweep service.
Hope this helped!
SG
P.S. The way to test my diagnosis is simple. Disconnect the dryer vent from the wall and start the dryer. That's it! You'll see the dryer will function normally.
Posted on Apr 05, 2009
canbruce75
  • 1776 Answers
SOURCE: Electric Maytag Neptune Dryer not heating up.
If the dryer won't heat up, the problem is typically either a blown thermal fuse or a faulty heating element. The thermal fuse is located just inside the back of the dryer on or near the exhaust duct. It is about one inch long. The thermal fuse and heating element can be tested using an ohm meter or multimeter. These components should have continuity. If either does not, that component is faulty. There is no telling if the moving around of the machine caused the problem or if the timing of the problem was coincidental. Sure hope this helps ya and best wishes.
Posted on Jul 24, 2009
SOURCE: AF Error Code
If thats not it, then you nay have a faulty sensor.
AF Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Posted on Mar 18, 2010
Testimonial: "Thanks so much!"
SOURCE: I have a Maytag Ensignia quiet series 200 electric
pu *** on timed dry instead of regular. This happened to me the other day and I don't know why :(
Posted on Nov 26, 2010
Hi, My maytag bravos dryer is one year and 2 months old. Suddenly it has stopped drying the clothes, it takes forever to dry a load and clothes are very warm and wet, lots of steam in the dryer, also the...
Sounds like the exhaust fan is not working. There's an electric blower at the back of the unit that forces air out through the exhaust vent. Unplug the unit, pull the vent off the back, and see if you can reach in and touch the fan blades and make them move. If it won't move something is probably caught in there. You may need to take off the back of the unit and remove the housing cover to the fan assembly in order to really tell what's going on, but it sounds like your fan has an obstruction. It could also be that the fan motor is fried but that seems less likely. Remember to have the unit unplugged, there's some dangerous voltage inside.
Jan 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a maytag ldg8200aaw gas dryer. it works and will dry clothes well but makes an extremely loud grinding noise as the drum turns...sometimes it even seems as if it is not engaging...I am trying to...
Your dryer is definitely worth fixing. The blower wheel is plastic 53-0106, These will wear out and get loose. Make noise and the clothes take a long time to dry. Repair Photosa9a0520.jpg
Mar 10, 2010 | Dryers
No Exhaust? Very Damp-not dry clothes
i would check for further blockage. also check the blower fan to make sure it is blowing properly. sometimes the blower fan can wear on the motor shaft and slip, thus reducing the air flow considerably. sometimes i have found the blockage just at the point of the blower fan.
good luck; jay
Jan 04, 2010 | Maytag MDE6000 Dryer
Dryer heats sometime but clothes do not dry well....vent pipes seem to be clear of lint up to dryer...blower doesn't come on...no air blowing out of dryer...
thats the reason your clothes aren't dry.Have to have air moving through tub. Check fan motor probably a thermal overheat fuse that has blown or if motor is turning, look at the fan and see if it has a set screw or retaining ring that holds it on the shaft or both fan may not be turning with the shaft. More than likely though the blower motor overheated or just plain worn out.
Sep 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer goes with 3-4 cycles to dry load of clothes
unplug the dryer.
Open the top lid.
Remove the front panel.
Inspect the blower wheel attached to the motor.
If it moves on the motor shaft replace it.
If iy does not move on the motor shaft, clean the lint out of the exhaust from the blower wheel to the rear of the dryer.
Mar 12, 2009 | Maytag Dryers
Takes almost 4 hours/timed cycles to dry 1 load of bedding/sheets
most of the time your complaint is the home owners house venting.run a load with the venting detached[it wont hurt a thing] if ok then must clean venting till dried as well as with out venting.if still long dry times first must make sure air ways in dryer are clean[should have good air flow at back if hand held there] and may need to remove front to clean lint filter area.and inspect blower ,making sure mounted to shaft and not worn in the center[blower key way, inside the hole where motor shaft goes thru blower]you dryer only has one element so if you have heat its heating.if you did all above and have problem still can be electronic[thermostats,timers etc........but i have fixed 1000s of dryers and their having problems are rarer.i hope that helps God bless ,tom
Jan 08, 2009 | Maytag Dryers
My dryer was making a horrible scrubbing noise and now won't dry
My 14 yr. old Maytag dryer made the same type of noise. It was the fan. The plastic had broken loose around the shaft. As the shaft turned fast, the fan turned more slowly, hence the noise. Replaced the fan ---- perfect drying and no noise. $26.00 for new fan.
Jan 02, 2009 | Dryers
GE Dryer model DBXR463EDIWW
If there is no lint blocking the air outlet path, I would next check two things: First, is the dryer in a small, closed room? If there is not enough space for air to get in to the dryer, it won't have good airflow through the clothes. Second, for older dryers, the blower fan may be loose on its shaft or, if the blower has its own separate motor, the blower motor might be dead. In order to find the blower fan, you'll have to be able to open up the dryer. Once you find the fan, see if it turns easily without moving the motor shaft -- if so, you need to replace the fan. Also, be sure there isn't anything blocking the blades of the fan.
Dec 30, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
166 people viewed this question
Top Dryers Experts
