Question about Toshiba 57H81 57" Rear Projection Television
Vs5065 Toshiba Jumps, has up and down lines, when first turned on, last maybe ten min till warmed up. after warm plays fine.
  • angelray Feb 12, 2008
    Thank you very much. Guess I will just leave it on 24/7 till it goes out comp. I am going to have to get a digital anyway pretty soon so maybe it will last till I find a good bargain..
    Scholar:
  • 44 Answers
Sounds like your vertical circuit is starting to go out. Probably the capacitors in that circuit. They are starting to leak and once charged up all way and warm they are holding. But it is only a matter of time before they go out and you will have the problem permanently. You should start looking for a reputable repair shop now. In fact, if you check out toshiba's website you should be able to find an authorized repair shop in your area. If there in none then check out the shops in your area. You should find one who is authorized with at least a couple of companies. Check on pricing. You should be able to get these caps replaced for around $100.00. Some companies will also come on site (yes, there are still some people who do house calls) though you will pay more for this service it saves you from draging the TV all over town. Anyway, this is not a problem you are going to be able to fix without some real electronic knowlege.
Posted on Feb 12, 2008
My 95 ford f150 runs great till it warms up it seems then the fuel pump looses power n shuts down wait few mins kicks back on runs fine till few min later
Sounds like your ignition module it is common on fords to do this when its cool it will start and run fine but once it heats up the truck dies until you let it cool down again and then your up and running till it heats up again. Some modules are mounted on the fender others are mounted with the distributor have it checked and let me know how it went.
Aug 26, 2014 | Cars & Trucks
Bad picture until tv warms up
well its a problem fo an ic causing the issue that needs to be replaced
May 30, 2008 | Toshiba 57HX81 57" Rear Projection...
Car dies when it warms up. just replaced carb, think it has to do with this
Vapor lock again! Make sure the fuel lines are away from hot surfaces, or insulated.
Also, when it warms up, the automatic choke turns off, and the idle setting has to be set to run at that temp. There will be idle jets, maybe two, and idle stop setting for the linkage.
Nov 26, 2013 | Cars & Trucks
Toyota 4cyl. truck bogs down backfires after warms up
Hi Bennie, When did you last replace the fuel filter? I believe a service may be the answer to your problem. If you have carried out a service recently, try replacing the fuel filter for a better quality product. Regards John
Feb 15, 2013 | 1992 Toyota Pickup
MY 1985 300 SE IDLES ROUGH AFTER IT WARMS UP
hi,seem you have leak on intake manifold or rubber seal on injector nozzle,be careful drop a little amount on kerosene on intake manifold and nozzle,observe if your idling get high the is there,maybe renew rubber seal on intake gasket,ty
Mar 24, 2009 | 1985 Mercedes-Benz 300
Jumps into manual 2nd gear
When was last fluid & filter change?
Nov 22, 2008 | 2000 Dodge Stratus
1995 LS 400 - car feels like jumping - suspension?
u need to  let cars warm up for 2 mins b4 leaving turn ignition on let warm for 2 mins car jumps u may have fuel problems maybe **** fuel or tank dirty
Nov 09, 2008 | 1995 Lexus LS 400
Htr shuts off after awhile and won't come back on till it's cooled down
I had the same problem with my heater. It was a cracked fuel line. I replaced the rubber hoses. On mine there was a pick up hose and a feed hose. They were dry cracked. Works great now. Hope that helps you out.
Nov 02, 2008 | Reddy Heater-30-55,000 BTU Variable
Picture Jumps/flashes for first 5 minutes
I had the same problem and followed the instructions from Jack and my 57h81 is bak up and running. Thanks Jack. RonD
Jul 02, 2007 | Toshiba 36HF72 36" TV
Toshiba 57H81 57" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
