Question about Philips 42PF9996 42 in. HD-Ready LCD Television
Phillips 42" LCD Mod#42PF722OA/37
I purchased four of these TVs on the same day at costco. It was October 06'. The first one went out in November 07' (just out of warranty) Contacted Phillips they said it was most likely a power supply problem. The repairs are over $800.00 only paid $1200.00 for the damn TV. So I went and just bought a Visio for $997.00. Now all four of the Phillips have gone out with exactly the same problem (but phillips will tell you it's rare). Turn on power hear a click, green light comes on, then begins flashing red. Has anyone yet to find a solution for this or should someone form a website to file against Phillips this is rediculous. FYI these were purchase for my corporate office coference rooms.
  • Anonymous Feb 24, 2008
    bought 42" phillips from costco late 06. we were watching it when the tv just turned off, now when we plug it in the green light comes on then the red light comes on and flashes 7 times fast pause and repeats the flashes. no picture or sound.
  • 106 Answers
This problem is related to two failures, one is the Power Supply Board, another one is the Y-Main Board. Troubleshoot procedures:
1. Disconnect the Vs Power Supply cable from the Power Supply Board,
2. Turn on the tv and check the Vs voltage on Power Supply Board,
3. If the Vs voltage is there, then the Y-Main board failed.
4. If the Vs is not there, then the Power Supply Board failed.
Posted on Jan 19, 2008
Phillips 42" LCD Mod#42PF722OA/37 picture is off
hi have you googled it or how to fix and put your problem then youtube should find video some where on there to help hope this helps good luck
Mar 04, 2018 | Philips 42PF9996 42 in. HD-Ready LCD...
Philips 42PFL7422D/37 42-Inch 1080p LCD HDTV Picture went out but still have sound. Any tips on how to fix it?
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Feb 16, 2011 | Philips 42PFL7422D 42 in. LCD TV
Multiplication table
x 01 02 03 04 05 06 07 08 09 ...
01 01 02 03 04 05 06 07 08 09 ...
02 02 04 06 08 10 12 14 16 18 ...
03 03 06 09 12 15 18 21 24 27 ...
04 04 08 12 16 20 24 28 32 36 ...
05 05 10 15 20 25 30 35 40 45 ...
06 06 12 18 24 30 36 42 48 54 ...
07 07 14 21 28 35 42 49 56 63 ...
08 08 16 24 32 40 48 56 64 72 ...
09 09 18 27 36 45 54 63 72 81 ...
Jun 15, 2010 | Mathematical Technologies Inc. MTI Tristan...
I need screws for an Olevia LT37HVS tv stand
Most of these sets us either a M4 or M6, around 22mm. this is close to a 2" long 1/4-20 screw, but in metric.
Home depot or radio shack, or just about any place that sells TVs these days ought to have them.
At radio shack, a wall mount comes with the following screws to fit all TVs:
  • 4 x Phillips screw (M4 x 10 mm)
  • 4 x Phillips screw (M4 x 20 mm)
  • 4 x Phillips screw (M6 x 12 mm)
  • 4 x Phillips screw (M6 x 20 mm)
  • 4 x Phillips screw (M6 x 30 mm)
  • 5 x Phillips screw (M5 x 6 mm)
Only caveat is don't go with a screw substantially longer than what is needed.
Oct 23, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Sceptre 40" 1080P LCD HDTV Display Upside Down
Sceptre X37sv-Naga 37 in. LCD Television
Vertical lines through the right side of the screen
Sorry sounds like you have a bad panel Try changing picture format if the lines don't dissappear or change bad panel
Apr 17, 2008 | Philips 42PF7220A 42 in. Plasma Television
Phillips 37FD9944/01S Plasma TV - Power Supply
dont waiste your money problem main or logic board or if shure power supply go radio shack and get one with specifications match voltage,ampers,and polarity
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
Black Screen after 5 mins. of use
Question when u loose picture do u loose sound also ? If so there is an 27Mhz xtal on the (SSB) small signal board that needs to be changed when it heats up it cycles out of phase. when it cools down it will work again till it heats up.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Green screen vizio lcd
My 37" vizio I bought in Dec 2007 did this (green screen at start-up on all inputs). At first it went away by itself after you left the unit on for 15 minutes, but then 2 days later the whole thing DIED. Luckily Costco has a 90 day return policy on TVs.
Vizio tech support suggested this (before it died that is):
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD.
Nov 27, 2007 | Vizio L37 Television
Philips 42PF9996 42 in. HD-Ready LCD Television Logo
755 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
