Question about Goodmans GPDR40 Digital Media Player
Switch on unit ok but it stays on initalise.
Where and how can I get software to resolve this please?
thanks
  • 24 Answers
This Sounds like your player has Crashed . you need to restore system files :
Posted on Jan 26, 2008
My computer starts up but then switches itself off after about 15 secs, both the psu and processor fans seem to be working ok, can you help please ? thanks
Does it restart when it shuts off, or just stays off? If it restarts, then shuts down, then restarts again, it's likely a bad power supply unit.
Apr 09, 2011 | Computers & Internet
I have an HP pavilion PC which will not stay on even with the adapter. I have replaced with new battery, still doing the same thing..
you need to check th power supply it maybe at fault another option is to remove all extras ie the memory and the hdd sounds daft but if you systematically remove each of them, and try booting the unit it may initalise. if so replace faulty part.
Sep 03, 2010 | Computers & Internet
I get an error of f 29 and my door won't unlock
Hi
Thanks for using FixYa. F29 is a door unlock error, this error occurs after the washer has made 6 attempts to unlock the door. Usually this occurs when the door lock mechanism is broken and/or the door switch/unit lock has failed. To resolve this issue you’ll need to check the door switch, door lock mechanism and the wire harness between the central control unit & door switch, replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I initalise the card in my fujifilm 500e ?
Insert the card. Go into the menu and find "format"...follow the on-screen instructions.
Feb 26, 2010 | Fuji FinePix E500 Digital Camera
Rowe Nostalgia jukebox will only play a few of the numbers of the 100 cd;s. Is there anyway to reset it so it will play all numbers?
You will need to go into the programming section on the menu.
I suggest that if you do not have a manual that you obtain one from Rowe Ami, Victory Glass or distribution.
Have you initalised all of the CD's on your jukebox? Every time you replace a CD you have to initalise it.
Regards
Alan Hood
ami-man
UK
Jan 31, 2010 | Wurlitzer Jukebox 1015 One More Time...
Screen says "unable to initalise" . It will send a fax and will phone on the speaker phone but cannot copy or receive a fax.
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Oct 26, 2009 | Brother MFC-620CN multifunction Color...
E36 318i k reg
when the window has reached the top position keep the window switch up for 15 sec,operate the window complete down and when down hold the window switch down for 15 sec test this after. all you are doing is to teach the control unit the limit stop and open position.
Jul 20, 2009 | 2001 BMW 325
4 GB CF will not initalise
Yea I have the same camera, and this camera only will works with a maximum 2gb card, because the camera uses fat16 format, and fat 16 will only adreeses up to 2 gb.
new models works with fat32 then they will works with bigger cards.
Dec 10, 2008 | Fuji FinePix S7000 Digital Camera
Image stay still on screen
No, its not a Skype issue. You may just need to download the correct software for your Logitech camera. You can download it HERE.
Next do a clean install..This is different from a regular install. Please follow the procedure carefully.
Removing the software and reinstalling it using a "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
2. Open the Windows Control Panel.
3. Open the Add / Remove Programs window.
4. Locate the listing for the software and remove it. When prompted to remove the camera drivers files, click Yes.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 19, 2008 | Logitech QuickCam Communicate STX Personal...
Problem on t.sonic mp3 player
Check the battery i think it`s dead
Sep 15, 2007 | Transcend T.sonic 610 MP3 Player
Goodmans GPDR40 Digital Media Player Logo
70 people viewed this question
Top Goodmans Audio Players & Recorders Experts
Pavel Pranovich
Pavel Pranovich
Tom Chichester
Larry
Are you a Goodmans Audio Player and Recorder Expert? Answer questions, earn points and help others
