Question about RCA RCU300 Remote Control
EMERSON TC1966D 19" COLOR TV
MFG Date SEPT 1992. It's been a super TV, 2 days ago I set the sleep timer and it went off as it always does. Turned it back on next day and now it's in video mode and I can't get my universal remote to return it too TV mode. I'm using an ALL FOR ONE 6L remote. Changed out batteries, re programmed..I'm lost!
Thanks in adance.
  • billieasbury May 28, 2008
    My sleep mode has been turned on for 9 seconds and I cannot undo it. Please help. Thanks in advance
If you have comcast, you can use that remote.
http://customer.comcast.com/Pages/HelpNFC.aspx?print=false&id=remotes
If you look at the number pad, the input button you seek is where the star key is on a phone.
I don't know if this will help with the sleep timer issue.
Posted on Oct 06, 2011
I have an Emerson TV and GE universal remote. How do I set the sleep timer
Posted on Jul 11, 2009
    Problem Solver:
  • 3 Answers
Try repairhelper.com
Posted on Jan 18, 2008
Tv keeps turning off by itself using auto shutdown function how do i turn it off
Check if the sleep timer is on. Go to settings and check under timer and check the sleep timer if it's on/off.
Sep 24, 2012 | Emerson Televison & Video
What year is my wood chipper? I purchased a Craftsman 8hp wood chipper-shredder that is silver-gray in color and all metal in construction with a Briggs & Stratton 8hp motor. The B&S motor is...
The B & S Code is the date of Mfg. This engine was built in 1994 (first two digits rep. the year), Sept.( the next two digits rep. the month) and the second day of that month. Your engine was built on Sept.2,1994. Your chipper may be one year newer as the engine had to be installed after the date of mfg. Your welcome
From North Carolina
May 17, 2011 | Heavy Machinery
The universal remote that I had been using for a few years started needing to be reset (without a code) every couple of days and eventually could not be reset. I thought it was the remote and tried a...
Hi, Not usually especially if the remote had a sleep timer button. the only excception is if the tvis fitted with buttons for accessing/navigating the menu functions from the local keyboard.
A quick way to verify if theremote is outputting any IR is to view the front of the remote with a digital camera/ phone camera etc whike pressing a button. you will normall see a white flickering light if all is well. note this doesn't confirm if there is good signal - more only an indication the remote is operational
Aug 13, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Black screen and no sound after a few minutes.
First, here is a copy of your manual in case it is missing.
http://www.warrantyweek.com/library/ww20061219/panasonic-th42px60u-manual.pdf
Next, check the settings of the sleep timer.
Select on the remote:
Menu.
Timer.
Sleep.
See if there is a time setting in there. You may also find a shortcut from the remote labeled "Sleep".
If this fails to resolve the issue, you can always reset to factory defaults. To do this, select from the remote:
Menu.
Setup.
Reset.
Hope this helps. Be sure to let us know how this helped.
Jun 30, 2010 | Panasonic TH-42PX60U Television
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
When i turn on the tv, it is on for abot 15 seconds then it turns off.
check the sleep timer make sure it is off or set to 00.00 could be set for turning tv off in 15 min
Mar 07, 2009 | Emerson Televison & Video
Color messed up on tv since lightning strike
your tv may have ben magnetized by the lightning strike.
tv's have an automatic degaussing circuit that demagnetizes
the pix tube when the set is turned on. this degaussing circuit
may not be working or magnetism may have been too strong for
the internal degaussing to correct.
contact local tv repair shop in your area see if they can manually
degauss your set , it should be a min. service charge around $25.
roland
Mar 22, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
No sound,volume bar works
Sounds like it may be something you did. Have you checked to see if you accidentally put the sound on mute? Try hitting the mute button on the remote control. Also, if the TV has the option to turn of internal speakers (which you would likely find in the menu under audio settings if it does) make sure they are turned on. If these checks fail then we have an electronic problem to deal with.
Aug 31, 2006 | Emerson EWC1903 19 in. TV/VCR Combo
RCA RCU300 Remote Control Logo
638 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
