Ricoh ft 3213 printing problem
I have a Ricoh copier that's leaving a blank line {erasing words in a colum. I need help in fixing this problem. I am not sure if's just a cleaning or durm problem. Thanks for your help.
  • 417 Answers
Is it only when you use the top feeder? Check by placing an original on the glass and copying if the same fault then there are three possibilities
  1. Optics Dirty (Dust on the copying mirrors) Remove glass and clean the mirrors on the scan unit also remove the lens cover and clean the mirrors under there replace lens cover clean glass and refit. (Do Not remove any mirrors you can clean them in there place and use a glass cleaning solution)
  2. Toner Waste and drum cleaning unit full. Open front cover and split machine as to remove jam not touching the drum (Large Cylinder ) check there is no banding on there. IF so to the left of drum there is a unit that contains the cleaning blade and fills with waste toner remove vacuum out waste toner check that cleaning blade ok and reinstall. Close and check machine if ok then great if not could be fault number 3 or that the cleaning blade is worn and need replacing.
  3. The fuser section (Heat section) While the machine is split look at the bottom left you will see a Orange unit this is the fuser section that houses the heat roller which welds the toner to the page. Check that the top roller is OK that there is no toner stuck on it and the Teflon coating is even. If not then the fuser will need replacing and as you said that you are missing text the most likely faults are going to be the fuser or the drum or the drum cleaning blade.
I hope this helps you
Thanks J
Posted on Jan 19, 2008
Printer leaving horiz black lines every inch down the page. Happens w/ printing normally and w/ blank pages which leads me to believe that something inside is dirty but I have cleaned everything I can
Are you using a new toner cartridge? If not they may be the issue, refilled ones can cause this condition. I know this first hand from my wife's office printer.
Oct 13, 2016 | Ricoh AFICIO SP 3300D 30PPM LASERPR W/O...
Scanner error 20 in hp ml005
Here's a quirky little fix..apparently if you open up Microsoft Word and print a blank document, the problem mysteriously goes away. Go figure!
I'm unsure if you need to leave word open or not, but you can experiment with that.
If that doesn't work, open up the printer and clean the curved lens.
Leave the printer unplugged from the wall for 20 minutes to clear the error state
plug the printer back in, and print a blank word document.
Now try using the printer as normal.
Feb 02, 2011 | HP LaserJet M1005 All-In-One Printer
Printing blank pages form my apple!!!
hi.. u can start by reinstalling driver for your apple here
after installing restart your apple.
May 15, 2010 | Ricoh Aficio SP C411DN Laser Printer
Ricoh 1224c prints on left side only - Blank on right side
well if its just on the black then it might be the black drum see if it does the same on the color from copying and printing. If it does the same in color then its not the drums it may be the developers, but you wont know untill you test the color if it only happens in black and white its definitely a problem with the drum.
Mar 25, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh FT 4015 too dark
Depends how many copies are in it. The PCU goes at about 60,000 prints its ordered as a supply. This is the heart of the machine. Lastly would be the fuser. -Carl
Jul 10, 2009 | Ricoh Office Equipment & Supplies
Copier Prints Blank Pages
My copier Mita DC 1560 prints blank. Any solution?
May 07, 2009 | Ricoh Aficio 2015 Copier
Extra blank page on ricoch printer
There could be a couple reasons...
  1. "Separator page" or "cover page" options could be enabled. The easiest way to find this option is to print a menu map from your machine. These are managed from the configuration page on the printer display
  2. Your printing from a terminal application, no fix...the terminal apps often send a (page break/ carriage return) at the end of jobs to make sure the page is printed and not held in queue.
  3. Check your settings in Office and print setup window - Word, Excel, etc. all have a "Seperator Page" and "Cover Page" options as well.
Hope this helps.
Jul 16, 2008 | Ricoh Aficio CL3500N Laser Printer
252 people viewed this question
k24674
jasbo
jasbo
