Question about Panasonic PT-47WXC43 47" Rear Projection Television
PT-47WX42F UNIT WON'T POWER UP BUT RED INDICATOR LIGHT BLINKS
  • 2 more comments
  • YOYOYOYOYOYO Jan 18, 2008
    3 times every 5 seconds
  • Anonymous Apr 21, 2008
    the problem i have is the timer light come on and sometime you can unplug and replug the TV the when you press power you can shake the red cables that connect to the lamp big thick ones, and it makes a weird click sound and it will come on but now it wont and the timer light keeps blicking three time ever five seconds
  • vandeclan6 Jun 27, 2008
    I just changed the bulb. It powered up worked fine for a minute or two (enough time to reset the bulb timer) and then went out. Now power light blinks and lamp light blinks.
  • Cary Farah
    Cary Farah May 11, 2010
    how many times does it blink and is there a pattern?>
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 18, 2008
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Open Questions:
Panasonic PT-47WXC43 47" Rear Projection Television Logo
118 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
