Question about Bose Cinemate Digital Home Theater System Speaker
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
Do not know how to connect cables to bose,tv,cable box
  • 1 more comment
  • Anonymous May 13, 2008
    how do i connect the bose systen to the tv and dvd to get surround sound
  • Anonymous Jul 10, 2008
    1. hooked up theater to tv still no sound
  • Anonymous Mar 18, 2014
    Samsung 65 inch TV sound went out but there is a picture i hooked up a bose speaker and still no sound
    Problem Solver:
  • 8 Answers
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Posted on Sep 12, 2009
How do i connect directv dvr and boes 321 to alg flat screen tv dvr is high deff
Posted on Aug 28, 2011
SOURCE:
I have a Bose 321 that I have connected to my TV and it works with no problem. I just bought a Panasonic Blu-Ray disc player and connected it to the TV using a HDMI cable. I then connected the Blu-Ray to...
hi,
u have to change the digital out setting of ur blueray player. change the audio output priority from HDMI to optical coaxial. surely u will get audio from bose.
ok
Dec 24, 2010 | Bose 3·2·1 Entertainment System...
Sound issues
make sure your audio out jacks are pluged into auidio in on bose and make sure it is pluged in under tv audio on the back of bose
Apr 14, 2010 | Bose 3 2 1 GSX System
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
I an lg47 240 hz flat screen hooked to a bose 3-2-1. I got the dvd to play through the bose and sound working through both the bose speakers and tv speakers, but when I try to get the tv to play through...
if you are using a hd reciever make sure the audio output goes directly to the bose system... if you do not have an hd reciever make sure its audio out on the television that you are using if you do have it hooked up right make sure the bose 321 is on the right input such as audio in!!!
if it still is not working exchange it.
Nov 18, 2009 | LG 47LG60 LCD TV
I have Bose 321 system w/ DVD player. I connected RGB cables directly from Bose to LG 42 inch flat screen. When i play a DVD, the image is in b&w. How can i get color?
That happened to me---there's something loose in the jacks leading out of the Bose to the TV. I thought it was just mine. You just have to jiggle them and you'll get color. That really sucks.
Jun 14, 2009 | Bose Cinemate Digital Home Theater System...
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
May 29, 2009 | Bose 3 2 1 GSX System
Sound comes only fron one rear speaker
Did you try switching Speakers A and Speakers B button on the AV receiver?
Jan 10, 2009 | Bose Acoustimass 10 III System
VOLUME ISSUE
I had my older bose 321 hooked up through vcr and sounded great. Then hooked it up through directv receiver and sounded better. then switched from direct to comcast and hooked the bose up throught the comcast hd receiver and the volume is aweful. same deal, have to crank it up high. Since the stereo built into the tv sounds so much better I disconnected the bose and am going to sell it.
Dec 28, 2007 | Bose 3 2 1 GSX System
Bose Cinemate Digital Home Theater System Speaker Logo
9,066 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
