Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore Dishwasher model 16779
My wife showed me the lower rack of our dishwasher.  The spikes that separate the plates/bowls etc. look like they were subject to extreme heat as the plastic on the spikes look melted and blackened.  A replacement rack will cost me in excess of $80.  I don't want to replace the rack and have the same thing happen again.  What is causing the melting/burning of the separator spikes on the lower rack of this dishwasher?
  • 868 Answers
Age/ poor quality plastic/sharp objects making contact/these are all common examples,I know there is a liquid plastic that you can purchase that really works and is safe to use.You wipe on the damaged areas and let it dry .
Posted on May 21, 2008
Where can I order a bottom rack for 19 year old Kenmore Ultra Wash III 16779?
May be difficult to find due to the age. Sears carries a lot of Kenmore replacement parts.
Mar 31, 2016 | Kenmore Dishwashers
Frigidaire gallery dishwasher not draining
Perhaps the screen in the bottom is clogged. Remove lower rack and lift off spray arm. Remove screen and clean then replace. Replace spray arm and rack. Always rinse food from plates, etc. before loading dishwasher. Not everyone does this in my house and I tell them not to be so lazy. For more serious issues try "RepairClinic" their site is really good.
Oct 15, 2014 | Dishwashers
My kenmore dishwasher leaves grime on all my glasses
It probably just has a build up in it, try taking a bowl and filling it with apple cider vinegar (you want cider vinegar because of the citric acid, you can also use tang or frozen o.j) then put the bowl full of vinegar on the lower rack in the dishwasher, do not just pour the vinegar into the dishwasher beacuse the dishwashers 1st cycle is too drain so it will all just drain out, then run the dishwashers heaviest cycle with nothing in the dishwasher but the bowl of vinegar. This will clear out all the debris and hard water deposits throughout the dishwasher. If it seems to clear up your problem try changing your dishwasher soap to Finish I work at a service company and have found this to be the best dishwasher soap on the market. Hope this helps.
Apr 21, 2012 | Hoover 24 in. DT999 Free-Standing...
How to load a dishwasher
Hello Lona Harrington, here is how the manual for my fridgearie dishwasher tells me and how I load it .
1. Upper Rack is for smaller items. Cups, small bowls,sippy cups, plastic bowls. all face down.2. Lower Rack is for larger items. Plates pots and pans. The plates should be upright. pots and pans face down.3. flatware basket. This is ware I disagree with the book manual. The manual says to put the tines of the fork facing upright and the same for the knives. I have young children and they are great helpers, but I don't want them hurt so I put all the sharp points down.Manuals are available on line free Hope this helpsJoe Connollysealstonetops@gmail.com
Dec 03, 2011 | Frigidaire Dishwashers
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
My lower rack will not clean bowls or cups and I have to be very careful how I place plates. The serviceman has been out twice and I have run vinegar through multiple times with no improvement. My top...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jan 06, 2011 | Dishwashers
I have a Kenmore model 1374 (ultrawash quiet guard). Recently I've noticed a lot of dirty residue left on the top rack dishes. I looked in the back of the dishwasher and noticed something with the little...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 26, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
My Kenmore quiet guard standard model 587-15152400 is not getting the dishes clean AT ALL. It has hot water, water is draining, have not changed soap. Don't know why?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Aug 22, 2010 | Kenmore Dishwashers
Top rack in Kenmore ultrawash not being cleaned
Check to make sure the upper wash arm is not plugged with debris. All Plates on the bottom rack and bowls on the top. Position the arm at 12 o'clock and check at the end of the cycle to see if it has moved positions.
Jan 20, 2009 | Kenmore 15899 Built-in Dishwasher
Kenmore DW model 15999 Lower Spray Tower Came off
Yes, I was able to get it fixed.
The spray tower actually fits in the rack (I had thought it fit in the top of the lower spray arm - wrong!)
If you were to look at the spray tower itself, it has 2 little clip like plastic protrusions that with a little twist will clip onto the lower rack!
Push the lower rack in and you can see where the center would be, (right over the middle of the lower spray arm ).
Now pull out the rack and take the spray tower and slip it under the rack up thru the bottom in the position you noted was the center (from above).
Now with the spray tower in place, slide the rack back inside the dishwsher and you will see that the tower will be sitting directly over the top of the exact middle of the lower spray arm.
Voila!
Nov 22, 2008 | Kenmore 24 in. 15999 Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
238 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
