Question about Toshiba 55H70 55" Rear Projection Television
The power converter has stopped working and we were wondering were we can get one to replace the old one, everyone we speak with say's that they do not make them for the 52in screen anymore, and we would like it to work again.
    President:
  • 4,402 Answers
Try here
http://www.voltageconverters.com/
Posted on Jan 18, 2008
Sputtering
Do a cylinder leak down test, to check for valves not sealing
If they are good, I would say your timing chain & gears are worn
& need to be replaced.
Everyone replaces parts for no reason, because nothing is visually
looked at, or anything at all tested, to even see if any parts are necessary.
Everyone lives in the 1960\'s, but fails to work like we were still there
& it bits you
Everyone skips the basics of the mechanical
condition of the engine
If it has a distributor, pull the cap off & put the motor at TDC
& I bet the Rotor doesn\'t line up where it should because the
top timing gear is worn & the timing is retarded
Need correct fuel pressure & can\'t have a clogged exhaust
converter
Mar 28, 2014 | Oldsmobile Cutlass Ciera Cars & Trucks
Proform Treadmill 785 E suddenly stops during highs speed workout
Use 2000W converter instead of 750W because you are using your treadmill on its full power on high speed. 750W converter is not capable of handling its full load resulting the machine malfunctioning. Your treadmill 785E have 2.25 CHP motor, 2.25 CHP is equal to 1677.824712W and 20-Amp minimum Ac outlet is required for your treadmill in order to function in full capacity. Download user's manual on: https://www.sportsmith.net/images/product_support/ProForm/PFTL785081%20-%20PROFORM%20I%20SERIES%20785%20E%20TREADMILL/PFTL78508.1-274823.pdf See Horse Power to Watts Converter on: http://www.rapidtables.com/convert/power/hp-to-watt.htm
Apr 16, 2017 | Proform Exercise & Fitness
Gmc yukon denali reduced engine power stability system disabled
I had the same problem in my Yukon Denali And after 4 throttle body's, replacing gas pedal, rewiring the grounds replacing sensors, took it to not one but two GMC dealerships who were useless they can't fix their own trucks they're not the brightest !!!! After thousands of dollars I found a mechanic very familiar with this issue you want the solution it will cost ya 500$ for me to tell ya!! Just kidding I know how frustrating this problem is okay here is the fix the problem is these electric throttle bodies are GARBAGE!!!!!!! Don't matter what u do or what u replace it will come back on unless u convert your electric throttle body to the old cable throttle the actual fix was 900$ but I spent thousands and thousands trying to fix it!!! Please save your money and tell ur mechanic u want to convert to the old cable throttle!!! Gmc is well aware of the problem but won't fix it for u cuz they're useless
Sep 24, 2012 | 2006 GMC Yukon Xl Denali
2on my 2001 cadillac the torque converter will be working just fine then at times after coming to a stop it stops working. The rpm's kickup. At times the check engine light will come on. Sometime the...
The torque converter can't stop working. The converter clutch can, but it won't cause the symptom you're having and neither will the solenoid. Check the fluid level, low level can cause the symptom you're having. If it does this more when cold than hot and/or does it more on hills it's a good indication of low fluid.
Apr 02, 2017 | 2001 Cadillac DeVille
Trying to find replacement for 375376-001 motherboard. wondering what else compatible. and wondering what result of substituting different motherboard means in terms of set up. machine has stopped...
If you just type 375376-001 motherboard into Google, you'll see places that sell direct replacements (as well as some ebay listings.)
The general listings I see tend to run over $200 for the mainboard. You may want to consider if it's worth a direct replacement or just putting the money toward a newer machine.
Oct 03, 2009 | HP Compaq dc7600 Convertible Minitower PC...
Bad gas mileage in last year
do a complete tune up with fuel filter change and clean out the injectors and the intake system
Jun 26, 2008 | 2003 Nissan Sentra
No picture no sound nothing
We had a TV repairman look at our 3 year old (Oct 2004) Panasonic CT-32HXC14J FLAT SCREEN TV. It suddenly stopped working and appeared to have no power getting to it. It was a high voltage supply or transformer that was bad and has to be replaced - estimated cost is around $400. In a year we will also need to spend around $125 for a digital converter box. We went for the repair since that is still cheaper than a $1,000 plus equivalent size LCD or plasma.
Our old tube tv was still working after 15+ years. They aren't making them like they used to. Way to go Panasonic.
Nov 09, 2007 | Panasonic CT-32HXC14 32" TV
The power has gone - Samsung LT-P266W
I need to know if there is a red led that is on, or if there are no lights at all that come on, it's important because it will tell which board to replace, if your trying to trouble shoot it down to the component that is bad, good luck with it. I would call in a repair man.
Mar 30, 2007 | Samsung LT-P266W 26 in. HD-Ready LCD...
Toshiba 55H70 55" Rear Projection Television Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
