Question about Brother IntelliFAX 2800 Laser Fax
Machine Error 76
What do I do to get rid of error 76 when trying to get rid of error 77 aswell?
  • 11 Answers
Machine error 76 is a bad fuser lamp. Machine error 78 is a bad thermistor. Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off.
Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
Posted on Jan 19, 2008
Which thermistor to change
Posted on Mar 05, 2008
What does a 77 error code on a Bernina sewing machine mean?
Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off. Sometimes the machines will give a false code and can be reset
that answer has been posted vk88
Mar 28, 2012 | Sewing Machines
Error Code 77 on brother 4100 fax intelifox business class
( 76 Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the front cover is
opened and closed, or the machine exits from the sleep mode. )
( 77 Power turned off and on at the occurrence of error 76 or 78. )
( 78 Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby. )
Nov 05, 2010 | Brother IntelliFAX 4100 Laser Fax
Error code 76
Fuser or overheat error it will probably be followed by a 77. Menu, mode and 0 quickly in that order will give access to user maintenace mode (lights will flash once your into the mode). Hit 91 to reset the machine. If this doesn't work you have a major problem with your fuser unit and it will need to be replaced. DO NOT DO THE ABOVE PROCEDURE MORE THAN ONCE AS YOU WILL START TO MELT STUFF IF THERE IS A MAJOR PROBLEM.
Aug 25, 2010 | Brother IntelliFAX 2600 Fax
Machine error 76 is appearing
Error 76 is a fuser error, you can try going in and out of service mode, press the following key combination all within 2 seconds " features or function , * , 2 , 8 , 6 , 4 , " if done fast enough the all the lights willl be flashing. Them exit out of service by pressing 99. If the error returns after startup the fuser will have to be replaced.
Oct 28, 2009 | Brother IntelliFAX 4100 Laser Fax
Error 77 is apprearing
Unplug the unit.
Hold down the menu key while plugging back in / powering up.
When finished initializing, hit 99.
Wait to status comes back and hit 91.
This supposedly happens due to a power surge or outage.
If this doesn't work for you try reversing the numbers above.
I have a bad memory, it might be 91 first then 99 but, you definately have to hold down the menu key.
Sep 11, 2008 | Brother IntelliFAX 4100 Laser Fax
Error 77
related to a fuser error. Unit is detecting a too high or low heat internally. Try turning off for a few minutes. If error returns check voltage level at outlet or try a different outlet. Maybe too many items plugged in same outlet. If error returns, may need new fuser or thermistor.
May 09, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother fax machine intellifax 2600
Feb 07, 2008 | Brother IntelliFAX 2600 Fax
How to clear a Machine Error 76
Error 76 is fuser error, you need to change the fuser but first just in case try to reset settings to factory defaults.
Nov 29, 2007 | Brother MFC 9600 All-In-One Laser Printer
Brother IntelliFAX 2800 Laser Fax Logo
3,456 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
