Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Cannon Rhapsody LPG Gas open Fire sooting up of burners
Burners sooting up with a large "ear" of soot after only a few hours use, clean them off and in no time at all they are back again, any idea's?
  • 2 more comments
  • rover57 Jan 18, 2008
    It is an LPG fire so no conversion. I'm thinking it may be something to do insufficient air flow (draught) on the chimney after reading several other web sites, what are your thoughts?
  • rover57 Jan 21, 2008
    Thanks Tech17 for the info, sorry for any confusion it's not a range cooker, not sure where that came from, it's an open LP gas fire, Cannon Rhapsody LPG. I guess the same rules apply about the pressure regulating valve, but as it was purchased LPG then I would hope that bit would be correct, may be worth a look though, any other idea's?
    Cheers!
  • robert samples May 11, 2010
    im not familer with the range but i am with the promblem did you buy it lp or have it converted
  • Anonymous Mar 14, 2014
    soot build up on cannon misermatic gas elements
I have a similar problem. My LPG cooker burner has suddenly turn yellow fire causing lots of soot - thats after I stopped using it for 3 weeks and changed a new gas bottle.
Don't wish to repair it though but just tell me if it is the burner (which is about 6 years old) or can it be the gas regulator (about 15 years old).
Posted on Mar 29, 2010
Get expert help...liquid gas is very unstable--very flammable!!!! Why endanger your life with a very few bucks
Posted on Jun 01, 2008
    President:
  • 1,314 Answers
Well its my experience that ranges don't come lpg they are all made natural gas but you convert them to lpg after purchase now if the lpg conversion isn't done properly then they soot like crazy proper lpg converson is to change the spuds on the burners and to turn the orifice over in the pressure regulator do you still have your owners manuel if so consult it on converting gas range to lp then check to see if every thing was done right on the pressure regulater there is a square cap you take it off and there is a round part that on one side says lp on the other says ng this changes the pressure that the regulator as ng and lp operates at different pressures and the regulator has to be set for what you using like i said im not familiar with your brand or model but i do know the problem if the range did come ng then you need to make sure the conversion most ranges aren't lp because there is not that big a market for it read the plate on the back will tell you if it was made ng or lp serial plate on front may say also most of the time it is beside the bottom drawer on the range
Posted on Jan 18, 2008
  • robert samples Jan 21, 2008
    look at the serial plate if it says lpg then thats what it came as also its posted on the site as a ge gas freestanding range lol now im not sure what it is is it like a turkey cooker or what
Soot coming
Hi there. Check the gas pressure, it should meet the the nameplate required pressure, low gas pressure produce poor flame quality which results in soot formation.. The type of gas must also be compatible with the orifice sizes on pilot and burners. Check and clean as needed all soot formation on burners and fire tubes.
Regards.
Sep 23, 2013 | Pitco Frialator 35C Deep Fryer
Deep fryer ignites but burner flames will not enter cylinders
Hi there.
Fire tubes may be clogged with soot. Have a technician inspect and clean the fire tubes for soot deposits/ build ups.
Check also if there is no air or ventilation directed on flue as it will push the flames back to the burners.
Regards.
Aug 12, 2013 | DCS Gas Deep Fryer 40 Lbs Double Basket...
Soot produced by propane heating stove
If it is still producing soot two problems blocked burners burning yellow causes soot , or blocked injectors, or pressure to burners is wrong needs seting to correct pressure
Feb 07, 2013 | Heating & Cooling
I noticed soot in my lp gas oven that had been clean. concerned when it started to ruin my food I decided to run the self cleaning cycle again. My whole house filled with toxic soot. My eyes were on fire...
Normally soot is from a range that hasn't been converted for the gas type, like natural or propane. It may be set up for natural when you're on propane or visa versa. Has this range ever worked properly without sooting?
Sep 20, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have an indesit cooker both gas and electric and when am using gas it produces poor quality fire which causes soot onto saucepans. please help
Soot is unburned carbon in the gas and is caused by the flame being short of oxygen. The burner assembly may be dirty or your air adjustment is off. Once a burner starts to make soot, it gets progressively worse on till it is repaired. The first thing to try is a good cleaning. If that does not solve it, look for the air adjusters. They should be near where the supply gas line meets the burner orifice. open them a little at a time and watch the flame for change. More air should clean up the cabon. Also check the gas pressure regulator for proper adjustment. It could be set too high. Let me know how your doing, OK? Roger
Apr 20, 2011 | Heating & Cooling
My fryer burns with alot of black soot
you need to clean the burners and the fire tubes, remove all carbon deposits.running the unit on low gas pressure results in carbon build up on burners and fire tubes.
Mar 11, 2011 | Pitco Frialator Kitchen Appliances -...
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
Soot build up
Flame is Orange? If so, propane is "choked", not enough air. Remove burners, clean each burner hole with a same size metal dowel (coat hanger works well) flush out inside of burner with garden hose, hi pressure air through all holes to dry. Replace burners ONLY after also cleaning chambers and chimney (garden hose and long brush). Do not forget to clean pilot light area too.
Most Imperials are pre-set air intake. Check gas pressure if able, 3" NG, 10" LPG. Good Luck
May 12, 2010 | Imperial IFS40 Deep Fryer
Calor gas and cookers
You need a C.O.R.G.I. (soon to be re-named "gas safe" in april) engineer qualified for LPG to sort this.
Jan 04, 2009 | Cannon 10476G Dual Fuel (Electric and Gas)...
Natural gas heater
The burners are shot. The heavy metal tubes with the holes that the burner flame comes out of, has burnt through. Instead of little rows of holes, there is at least one large hole in it. Unless someone has changed the gas>air mixture, you need new burners.
Mar 13, 2008 | Empire DV-215 Direct Vent Natural Gas...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
603 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
