Question about Sony Playstation 3 (PS3) Console
PS3 video issues using 1080i
I am attempting to hook up my PS3 to my HDTV using 1080i resolution. I am using a cable that connects to the AV port and breaks out to component plugs. I am able to configure the PS3 for 1080i via the configuration menu, but I have colors slowly rolling from the bottom of the screen to the top. The colors are green or red. What cable options should I use in the setup and should I use the auto configure option that I've read about?
  • dcros4 Jan 19, 2008
    I don't have an HDMI input on my TV. What settings do I need to work with the component cables?
  • 182 Answers
The best cable to use is an hdmi cable, so long as the tv has hdmi sockets. you shouldn't pay more than 20 pound or 40 dollars for a good one. hope this helps
Posted on Jan 18, 2008
Dynex HDTV says not supported when PS3 is connected via HDMI
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv size...select the size- now you need to set the resolution...select all resolutions that the TV supports, since it is a dynex...it is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Mar 21, 2014 | Video Game Consoles & Games
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
I am trying to connect my ps3 to this TV. i have tried with AV ables and through HDMI but it does not seem to work. is there a problem with compatability?
hi,
PS3 outputs hi definition video through HDMI ie 1080p. Your tv will not support that resolution. Because its a HD ready one ie 1080i. If you wnat to connect the PS3 through the hdmi then you have to down convert the video output resolution of PS3 to 1080i. for that you have to connect the PS3 to any FULL HD tv and go to the HDMI video setup and down convert the resolution to 1080i. After that you can connect the PS3 to you tv. Surely you will get the video.
There is one more way to get the video in you tv. connect the PS3's component video output to the component video input of you tv and the audio output to the corresponding component audio input . Select component video input on the tv. You need a component video cable and a stereo RCA cable for that.
ok
Aug 29, 2011 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
Trying to hook up PS3 to Panasonic viera LCD hdtv with HDMI cable and tv is not reading it and has no picture or sound. What may be the problem? Thanks!
hi,
ur ps3's HDMI out is a full hd video (1080p). if u r tv does not support full hd this problem can occur. do one thing. connect the ps3 to any full hd tv and go to its video setup, then down scale its video resolution to 1080i. after that connect the ps3 to ur tv. u will surely get video.
ok
Jan 11, 2011 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    I have a HDMI problem with my PS3. I have it
    You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
    May 14, 2010 | Sony Playstation 3 (PS3) Console
    Can't get video to work on Ps3 system compossite cables
    First make sure that all of the connections are securely connected. If it still doesn't work try another set of cables. Also ensure that your setup menu on the PS3 is set to the correct resolution. If you are using the standard definition connection (3 RCA type connections labeled VIDEO L-AUDIO-R) make sure your resolution is set to 480i. If all of those steps are correct and you still can't get it to work then your Analog Video board might be defective. You will have to get this serviced by your local PS3 repair center.
    Mar 04, 2010 | Sony Playstation 3 (PS3) Console
    I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
    1. Check the resolution supported by your TV.
    2. Select (Display Settings) under (Settings) in the home menu.
    3. Select [Video Output Settings].
    4. Select the connector type on your TV.
    D2: 480p / 480i
    D1: 480i
    5. Change video output settings.
    6. Set the resolution.
    7. Set the TV type.
    8. Check your settings.
    Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
    9. Save your settings.
    The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
    Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
    Sony Playstation 3 (PS3) Console Logo
    132 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
