2004 ford explorer...door ajar light is on all the time...no dinging when you open the doors...only when you open the hatchback.
SOURCE: 2004 mercury mountaineer door ajar light
Ends up being a broken wire(ground) in the rubber boot between door and frame. I carefullly removed door panel, pinched the ends of the boot and slid it back into door. And there it was...a broken black wire. Spliced in a new piece of wire, reassembled everything else. Everything works like it should. It's really not that hard just take your time. Also before I started I disconnected the battery as a precaution. Goodluck.
SOURCE: Battery was draining. Had to jump it with my Subaru.
do you have any subwoofers or a loud sound system in your car? sound to me like inner damage due to vibrations from extreme sounds?
SOURCE: Door Ajar Light
the switches for these vehicles are in the latch and they seize up from time to time. you will have to spray some penetrating oil into the dor and rapidly close and open the door hard to try and fix it. if that doesn't work then you will have to figure out which door it is and replace to latch. note if key is on, the dash will make a tone everytime you open and close door. so the door that doesn't chime that is the door with the issue.
