Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Lamp light My red lamp led light is still flashing after replacing lamp with a new . I had the light engine replaced ( less than a year ago) and it quit working all together. (black screen). The lamp light stayed lit so I checked the lamp and it was broken (glass shattered in bulb. I assumed that was it so I ordered a replacement lamp. installed it and now the light still blinks
  • 2 more comments
  • Anonymous Jan 19, 2008
    same issue, just got my new lamp today & the light is still blinking
  • Anonymous Jan 27, 2008
    Have the same problem.
  • Anonymous Feb 06, 2008
    Black screen, temp and lamp red light flashing!
  • holyhatachi Feb 06, 2008
    Same problem! I replace the original lamp with a new one that resulted in the blinking lamp light. I figured I received a bad or wrong new lamp, wrong, when I put the old one back, which was still working, it didn't work either and the lamp light is blinking????????????
  • 50 Answers
Check the lamp switch that is located inside the door. Place the lamp in, and stick a flathead screwdriver in the slot (just make sure it moves) hold it there, and turn on the Tv. If that doesn't work check the new lamp, is it a generic lamp, if so they dont always work. If you still have your old orig lamp, take the old lamp out of that housing, and out the new lamp in the old housing. This should fix the problem.
Posted on Feb 09, 2008
  • Nick Newman Feb 13, 2008
    If you have a blue circle in the middle of your screen, your light engine is going out.
As a follow up to my problem with the blinking red lamp light, I did check the lamp switch and actually pulled it back to be sure it was making contact as well as the switch inside the lamp box. What I found out was that you need to put a little extra pressure on the lamp box when you insert it and I actually felt a click as the electrical connector seated together which I did not do the first time. I tightened up all screws and covers and everything worked again. Found out that the new lamp doesn't fix the red blob or the blue light in the center of the screen. I will tackle that one next with Hitachi?????
Posted on Feb 12, 2008
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
Sound but no picture; little red light showing instead of green led power indicator. less than two years old. original owner
Tv LED light indication"LAMP" is flashing or staying on?Yes 2 years old projection lamp and watches tv daily 4 or 5 hours a day?Yes,it is time to replaced the tv projection lamp.
Feb 18, 2011 | Mitsubishi WD 65837 65 in. HDTV
Have an 52HM95. Man.- 01-2006. Rent-a-center had the lamp (I believe) replaced when this happend the first time 3yrs ago. . It cost them around $200. Now 3 years later, its paid off, so, NEED HELP! (No...
The "LAMP" LED light indication on the front of the tv screen panel flashes or light up?The projection lamp was replaced 3 year ago u belive right?The average projection lamp life about 1 1/2 or 2 years.Withthin function in the tv and in used like 4 or 5 hours a day of tv viewing.Ur tv require a new projection lamp.
Sep 18, 2010 | Toshiba TheaterWide 62HM84 62" Rear...
My KF60XBR800 will not always power up when we
Replaced the projection lamp again.Sony projection lamp more expensive,but last longer too.Genaric projection lamp brand last about 1 1/2 max.U hear clickinng sound too,when LED light flashes?Mean the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Jul 07, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
How to tell if lamp is dead? Lamp strikes 5, Red LED flashes once over and over. All whirs and whines as normal. Removed bulb housing, one side half-caked with dust, vacuumed it. Removed bulb, looks fine...
the lamp needs replacement.as per the manual.
the light flashes 5 times.this is the indication to replace lamp.
replacing the lamp should solve the lamp.
Lamp strikes 5, Red LED flashes once over and over the solution is lamp replacement.
for getting lamp you can get it from
www.partstore.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Mar 03, 2010 | InFocus ScreenPlay 4805 Multimedia...
NO PICTURE OR SOUND
Hi
Usually, if the red light is flashing and you get no picture, that means that the lamp life cycle is finished and you'll have to get a replacment lamp. the lamp has about 3000 hours of life (2 to 3 years under nomal use).
You can buy a replacment lamp from here
http://cgi.ebay.com/NEW-DLP-LAMP-BULB-JVC-FOR-HD-61G787-HD-61G887-HD-61Z456_W0QQitemZ320274762989QQcmdZViewItem?IMSfp=TL0807151554r7572
Hope this helps
Cheers
Aug 10, 2008 | JVC HD-61Z456 Television
Dead sony
The $1200 was for the lcd engine not the lamp. You should change the lamp. The buzz is the power supply trying to light the lamp.
Apr 25, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Mar 21, 2007 | Mitsubishi WD-62525 62" Rear Projection...
My 60" lcd projection tv wont turn on sometimes and throws a lamp light, and if i watch tv for a while and turn it off it wont turn back on and throws the red lamp light
The buzzing sound you most likely hear is the ballast trying to fire up the lamp. I would say replace the lamp and yes they can act up at will. If this is the first lamp replacement ever then you are doing good.
Feb 01, 2007 | Hitachi 60V500 60" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
421 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
