Vizio P50HDTV10A 50 in. Plasma HDTV Logo
Posted on Dec 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 50" Plasma blew a 8amp fuse at the power supply. I replaced it, and the TV works again, buy why would this fuse have blown in the first place?
Dave Naylor
Level 3:
  • Master 834 Answers
  • Posted on Dec 07, 2009
Dave Naylor
Master
Level 3:
Answers
834
Questions
Helped
223420
Points
2476
If the fuse was at the or near the AC plug chances are your got a power surge, if you did you got very lucky the fuse was there you might want to get a surge protector on the set ... But sometime you get just a defective fuse as long as the set is working I would not worry about it
My fuse blew in my Samsung 53" Plasma TV. I changed it, but it's blown again? What should I do next?
The fuse blown because theres a short circuit connection in the PCB power supply of your television.Please check the power supply inside,remove the back cover to see the power supply section.unplug first to avoid electric shock.Will you check the bridge type diode first.If the bridge type diode or diodes is shorted the fuse is always blown.Using digital tester check diodes,regulator transistor,and other transistor around the power supply.
Hi, i was given a NEC 50" plasma tv model #
What is the problem you faces with it now? If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
4helpful
2answers
My vizio is three years old one day watching it and then off no picture no sound no led light is there a reset or a fuse
Had EXACT same thing happen this week. Same TV as yours, 3 yrs old (purchased Feb 2008, Costco). TV wouldn't turn on, and usually does a "click-click" when you insert the power cord and now nothing.
Solution - had to replace a single $1 fuse.
1) Put tv face down on a flat surface
2) remove legs
3) remove back (there's like 30 screws with 3 different sizes/threadings)
4) right where the power connects up to the big main brown circuit board, there's 2 fuses flanking the sides of a white clip.
5) I test the fuses and the one on the left blew out.
6) Fry's + $5 for 5-pack of Slow Blow 8amp 250v fuse = fixed TV.
I would bet that it's the same for you. A little labor, but much cheaper than a new tv or repair shop.
Note, the fuse is a litte hard to remove, just try to put something underneath it or maybe even pry it out with plyers. It's ceramic so pretty hard to break but still don't squeeze with the plyers too hard.
You'll need the 5mm x 20mm, ceramic, slow blow out 8amp 250v fuse. Radio Shack doesn't carry it. Fry's does. As I'm sure other places online will as well.
2answers
I have a Panasonic TH-50PX75U Plasma 50" tv. The
I had the same problem call sears it's only $99 to come out and free estimate. mine cost $300 and it works great. mine was a circut board had to be solderd back in
1helpful
Sanyo DP5747 Plasma TV no power
Found 1 of the 2 ac supply ( 8amp) fuses blown on the main pwr. supply. Replaced fuse and good so far. Looked over the ps for damaged components, none found. Checked current with ampmeter with tv on, showing 3amps. Cheers
1helpful
Won't power on...
The TV probably has an internal short, most likely in the power supply. If you open it, you will probably find the main fuse is blown (which is why it didn't trip the breaker again. Don't bother replacing the fuse until you find and fix the short - you'll just blow the new fuse and probably trip the breaker again.
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
3helpful
3answers
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
