Question about Sony Playstation 3 (PS3) Console
Does not want load any disks
Erased everything tried to reboot but now will not read any disks
  • 182 Answers
Its a problem with the latest download update. sorry to say but its a job for sony as long as its still under warranty. just phone them up explain the probs your having and they will send you a new (normally reconditioned) unit out. i'm getting my new one tomorrow. upset it broke but sony's replacement service is very good.
Posted on Jan 18, 2008
I want to give away my D620 emachines laptop, but want to reset if first so all my personal information is erased. How do I do this?
In order to completely reset all personal information, the only failsafe way is to wipe the hard drive (and even this is not failsafe).
Look at this program. This program will allow you to make a bootable disk (eg USB). After you create the disk, reboot your computer and press the Boot Order key (on a Dell D620, its F12). Select USB. The Kill Disk program will load, allowing you to completely wipe your hard drive (eg. by overwriting everything with 0's). This will probably take a while, depending on the size of your hard drive.
Apr 30, 2011 | E-Machines (T2958) PC Desktop
How can i erase everything on my laptop
hi ,
put the XP cdrom or a recovry disk in your dvd drive, reboot your laptop, when you see the message " press any key to boot frm CDROM" you must press any key (space key for exemple) and then it easy you should read the message displayed and answer by heating the specific key. to erase all data in your hard drive press D to delete the partition and then press C to create a new partition. but after finishing the setup you must install the divers from the CDROM delivred with your laptop.
Oct 25, 2010 | Computers & Internet
It does not load maps
Your probably loading the maps OK, but the numbers your supplying the program and you 3600 are not compatable.
1. Make sure you have software that came WITH your unit..... It will not work with anothers discs.
2. Do a total ERASE of the disk and your 3600 both. Use your computer do erase the chip disk, and read your book how to do a total ERASE of your unit.
It is critical that you use the correct software.
Try this first, if it does not solve problem, get back to us.
Kindly,
Jim
Nov 28, 2009 | Garmin iQue 3600 GPS Receiver
I lost my recovery disks during move now i cannt reboot system theres a problem on hdd it says no room left so now wont let me make any recovery disks yet there is nothing on hdd
Start Internet Explorer.
Click Tools.
Click Internet Options.
Click Delete Temporary Internet Files.
Close Internet Explorer.
Click Start.
Click Run.
Type CMD and press ENTER.
Type CD LOC and press the TAB key and then the ENTER key.
Type CD TEMP and press ENTER.
Type ERASE * and press ENTER.
Type Y to confirm that you want to erase everything in this "temp(orary)" folder.
Type CD \WINDOWS\TEMP and press ENTER.
Type DIR and press ENTER.
You should see something like:
20 File(s) 3,165,781 bytes
20 Dir(s) 1,443,053,568 bytes free
i.e., where 1.4 Gigabytes is enough space to hold about 2 full CD-ROMs of data.
Find a USB memory-stick that is mostly "empty", and connect it,
to create more "available" disk-space, e.g., 1 or 2 or 4 or 8GB more.
Now, try to make the recovery disks.
Nov 18, 2009 | Acer Aspire 5315 Notebook
Windiws cannot access the disk
try using the program Killdisk. This will permanently erase everything that has ever been written to the HD. Whenever I run into this problem, I run this on the HD and Presto, setup now recognizes the drive.
http://www.killdisk.com/downloadfree.htm
However, if this is a SATA drive, sometimes certain drivers must be loaded first. These drivers can be found at the manufacturer website. Once downloaded, you will have to use a floppy disk to load them (or usb flash drive if it is set up as bootable device). To load the drivers once downloaded and stored on bootable device, you will have to run winxp setup and press F6 when prompted at the bottom of the screen to load third party raid or scsi drivers. When you press F6, nothing different will happen. Setup files will continue to copy and setup will again try to look for your hard drive. When it does not find it, you will be prompted to look for drivers on your bootable device (the floppy/usb drive you loaded the drivers on).
Just note, after using killdisk, data recovery will not be possile for the partition you erased by using killdisk. What this means: Everytime your format a HD using Fdisk or windows setup, nothing is technicaly erased until that particular spot on the HD is written over, that is how data recovery businesses restore lost or erased data. Once you run killdisk, it re-writes over all data making it completely invisible to partition recovery programs. If you are not worried about any data on the disk, then this should be no concern for you, just some info.
If this does not help, I will be happy to walk you through the manual HD setup in winxp setup procedure, it is quite easy once you find what you need.
Hope this helped!
Oct 07, 2009 | Asrock K8Upgrade-VM800 Motherboard
Reboot problem
try puting a new cd or dvd drive has it may not be reading the cd right
Nov 30, 2008 | Acer Aspire™ T180 PC Desktop
Got following error: Load Error! Press any key to reboot
This problem is indeed caused by a faulty MBR but there are solutions other than zero-filling the drive.
If you can get access to a RipLinux CD there is a little utility called Testdisk that will write a new MBR code to the first block of the drive. I just did this on a Sony PCG-K15 this morning (after cloning the drive just to be safe) that was giving the same error of "LOAD ERROR- Press any key to reboot" and it worked like a charm. The machine booted right up.
Hope this helps...
May 09, 2008 | Computers & Internet
Erase everything from my hardrive,start fom cero
You can erase all the data in your harddrive by formatting it. If you have installer of windows insert it to the cdrom or dvd and change the booting options in the cmos or bios setup to boot in the cdrom. Reboot the computer in follow the instruction how to install in format the hard disk. Delete the partitions and create a new one to avoid the virus stay in the sector of the disk
Apr 15, 2008 | Computers & Internet
HP Pavillion 533w System restore disks
You should be able to do a clean format with the hp disk on a new drive.Basically start from scratch.I have put new drives in HP computers without any trouble
Feb 20, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
14 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
