Question about Xerox Phaser 8400DP Thermal Printer
I have error code 07,010.43:41518 What does it mean?
The above error code will not allow me to use the printer, this is the first problem like this we have had with the machine. I have googled, read the Xerox web site and nowhere can find what the code means.
  • Wabrit Jan 18, 2008
    Thank you for identifying the problem, any suggestions on how to fix it?
    Thank you I will give it a shot.
    President:
  • 2,072 Answers
That is caused by the print head not pivoting from home to print position.
Here are the probabilities.
1. The staineless steel pivot block, that the print drive shaft goes through has had some, most likely yellow ink seeping into it and had made it slow to move back and forth. That is the most likely issue.
2.The machine was unplugged or there was a power failure and the print head wiper blade has tacked to the print head.
3. The cables to the print head are hanging up not allowing free movement of the print head.
4. The Media path motor geat chain is out of timing. That is unlikely, but a possible cause.
The easiest way to prevent that code is to make sure the printer is level front to back and side to side.
Also, the print head is possibly bad.print head, but unlikely.
Posted on Jan 18, 2008
  • 1 more comment
  • Rick Kasper Jan 18, 2008
    Yep,
    You have to remove both side covers. From the front look for the steel block. About 1 inch square. Looking from the front, it will be on the left side, lower portion of the frame, near the middle.
    It has a spring loaded bracket on it. Look at that block and see if there is ink spilled into it.
    IT IS HOT. You can pull the spring loaded bracket off and mount it to the upper left notches to locate it.
    If that block is gummed up, it can be pretty hard to remove. But once removed, the best thing to do is place it in a pan of hot water to soften the ink thats on it.
    Then continue to clean that block and also the print head shaft until you remove all the ink and it can move freely.
    Getting the Wiper off the print head also requires removing the ink loader. The area where you load the ink. It is held in by plastic tabs, and also there are 2 cables connected to it.
    Once that is removed you can look between the drum and front of the print head and see if the blade is tacked to the print head. Gently try and remove it from the print head. Then you can cycle up the machine, It may take 3 or 4 cleaning cycles to get all the excess off the print head.
    When you have that ink loader off you can see if the cables are binding the print head.
    the media motor is different to adjust. Check the print block and wiper first. And remove all excess ink in the block area before treturning it to service. Remember, the ink loader and print head are HOT. Let the machine cool for a while before servicing. Remove the power also.
    Then make sure the machine is LEVEL front to back and side to side to eliminate ink leaking.
    Removal of the print head if needed would involve several more steps, If you need to do that let me know.
    You will need either a torx set or a 5.5 MM nut driver for cover removal.
  • bcmarshall Jan 20, 2011
    I realize this is a very old thread, but I ran into the same error code and found you through a net search.
    I followed your instructions, and found indeed there was some yellow ink around the square block. I cleaned it, and removed the ink feeder and manually moved the print head back and forth. The wiper is definitely not tacked to the print head.
    Do you have any idea what might be causing this issue?
3 Suggested Answers
  • 2072 Answers
SOURCE: xerox workcentre C2424 printer
That means your print head is not tilting back and forth properly. Or moving side to side.
The 2 most likely causes are this. 1. If you remove the side covers, behind the left cover, ( left looking from the front of the machine) about half way back, near the bottom of the machine you will see a stainless steel block, about 1 inch square. Check that for the presence of ink that has leaked into it. normally its yellow. You will have to remove that block and clean it and the shaft that runs through it thoroughly.
2. The print head wiper, That is located between the print head and the drum. You would have to remove the scanner and the ink loader to access that area. But if a machine is not turned off correctly, unplugged or you had a power failure, it may be stuck to the print head. Which you would just have to take care and dislodge it from the print head then run a couple of cleaning cycles, or power on and off a couple of times.
3. You could have a bad wipre blade clutch but thats less likely. If there is alot of ink in the block, clean all around that area, and then, be 100 percent certain the machine is LEVEL. To check. put a level on the platen glass. check for level front to back and side to side, If it isnt level, shim it until it is level. And dont move, I mean relocate the machine when its hot.
Posted on Oct 31, 2008
  • 57 Answers
SOURCE: xerox phaser 8560 DX error
This fault occurs due to the printhead being stuck in the tilted position. There are many reasons why this fault will occur, too many to mention.
More often than not, your problem will require the printhead and process gear to be re-aligned in order to get a reboot but sometimes it is possible to get a reboot by doing the following;
Turn the printer off, wait ten seconds then turn it back on again. Wait for the printer to start warming up to about 5 or 10 percent. At this point, switch the machine off again by the machine switch NOT your wall/plug switch. Wait ten seconds and switch on again. Now let it run through its normal cycle. The success rate for this method is small, possibly only 1 in 30 machines will recover.
The reason this will sometimes work is that, when you turn the machine off from the warm up, it powers down using its proper head parking routine, you will notice, it takes a while to shut down. If the original fault was due to say a power cut or someone pulling the plug out it is possible for the printer to find its home position and boot ok.
Unfortunately, a lot of the time, the reason for the fault is printer related and such, this method does not work. But it is always worth a try.
Hope this helps.
Posted on Jan 19, 2011
What is Error code 0x4D mean
0x4d is error recognising the printer cartridge
Jan 07, 2016 | Epson Workforce 610 All-In-One InkJet...
What does error code 99,013.00:49569 mean xerox 8570 color cube?
Process Drive Fault"
Do you have another kit you can take from another printer.
Switch the printer off.
Swap out the kit with the one from the other printer.
Turn it back on. If it clears the fault when the printer is ready put back the new kit
Aug 14, 2015 | Xerox Office Equipment & Supplies
Erorr code 4003 zebra zxb8
Error Code 4001
System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
Error Code 4002
System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
Error Code 4003
System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
Error Code 4004
System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
Error Code 4005
System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
Error Code 4006
System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
System Error Codes
Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
What does the ! mark mean on the top of the printer when it is lit up?
The "!" means that the printer requires your attention. It could mean that there is a paper jam, that it's low on ink, that the printer is low on paper, etc.
If there is an error message associated with it and it's now allowing you to print, post it here so someone can identify what the error means.
Jan 21, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
The ink light keeps blinking but the cartridge is full. Also what does the E above the plain/photo paper panel means.
Hi, you can use this link to know possible codes for HP DeskJet F380 All-In-One Printer.
printertechs.com/tech/error-codes/error-codes-A-E.php
Nov 16, 2010 | HP DeskJet F380 All-In-One Printer
hope it helped.
Thanks for using fixya...
Oct 27, 2010 | HP DeskJet F380 All-In-One Printer
925 fatal error
www.okidata.com/canada_en/downloads/C9600_Bertl_4Stars.pdf
all in manual above. http://www.okic3200n.co.uk/index.asp?printername=C3200n&menumode=0&content=errorcodes
error codes above.
Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
May 08, 2010 | OKI C9600hdn Laser Printer
Error code Ox88108508. Printer starts to print then stops. Error code pops up even when computer is turned off
hhhmmm try to download a resstter for your printer model, cause that error code cud mean that some part of your printer has reach its limits, printers nowadays have a counter in it. if you cant find any resetter software for your printer you shoukd call the HP tech. support cause they are the only who knows the right key combination on your printer panel that allows the parts to be reset.
for more help visit Cbr tech solutions
Dec 07, 2009 | HP PSC 2355 All-In-One InkJet Printer
Canon MP630 error code 6502
Error 6502 is the ink tank position sensor error. Basically means the printer can't see the inks. Try reseating them. If this fails you need to send it back.
Jun 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Xerox Phaser 8400DP Thermal Printer Logo
908 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
