I would first need t know the model of your PC before telling you what would be a wise upgrade.I would first need t know the model of your PC before telling you what would be a wise upgrade.
You can't post conmments that contain an email address.
Re: I want to upgrade my memory. can you tell me what...
Before you upgrade ur Ram, you must knw the size of it, either DDR1 or DDR2 before you can upgrade and if your PC accepts the speed you want to install in your machine.
You can try, but instead of purchasing it rather take your PC to a computer shop and tell them that you would like to install 2GB of RAM, would they please see if it would work. If it works then you can purchase it and if it doesn't then you wouldn't have wasted your time and money on some-thing that you have no use for.
First find out if 4Gb sticks of the right type are available for your machine, and that the machine supports that much RAM. Then make sure you carefully order 2 x 4Gb sticks.
You have purchased the wrong type of memory or one of the memory sticks are bad.
Try inserting just one at a time.
If the same problem, re-install the orig. memory and replace the purchased memory.
You can go up to 3GB of ram with a 32-bit operating system. A 64-bit operating system is needed to use 4GB or more.
In your case, you should be able to, as long as you have the memory slots. If you're out of memory slots, you will have to purchase a stick with higher memory density.
Memory type is the major problem with the 741GX chipset. Very touchy. I used Crucial PC3200 High Density memory to start with (2 x 1 gig Memory), system was lagging even though adjusted settings in bios. whenever a USB device was pluged in, the system would stop responding. Switched to low density memory and no problems since (Ultra PC3200 (2 x 1 gig Memory), and the USB device problem is also solved. I am running WinXP with SP2.
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
Computer Memory Information
Upgrade Questions Troubleshooting Memory Diagram Upgrade Help Buying Tips · Memory definitions. MEMORY ABCs. Memory, which is commonly referred to as RAM
Installing PC computer memory
Additional information and help with isntalling PC computer memory. ... Installing a PC computer memory. Question:. Installing PC computer memory.
Determining type of hardware within computer
Reference, Issue / Question. Memory, Information and help with computer memory. CH000149, How to determine system resources / RAM available?
Buying tips on computer memory.
How much memory should I get? This question really depends on the type of computer user you're and what type of programs you plan on running on the computer
