Question about Philips Magnavox MWR10D6 DVD Recorder
'Cannot Record On This Disc' Error
I've had the unit for almost 1yr. From the 6month on period I have constantly been getting the error "cannot record on this disc" for new DVD-Rs. Sometimes I get it with the DVD-RW if they've never been recorded on. This is annoying. The error seemed to happen off and on, but now it seems steady. I've now been trying to record for the last 4 days, and I continue to get the error. I've tried all differen't brands of DVDs - Maxwell (like recommended) is what I am currently using. The unit seems to be overall buggy as heck.
Someone please help. The Owner's Manual says to contact www.funai-corp.com yet they have no mention of this product on their site. I DO have an email out to them for help however. The Philips website doesn't have any product for this either, same with Magnavox last time I checked.
I was having other issues such as the DVDs not writing/finalizing, and the only way to cancle it to repair was to unplug the entire unit, which as you can imagine is hard to do behind a huge entertainment center.
  • Kat9119 Jan 18, 2008
    The disc I am currently using says Maxell UP to 16x speed. I've been able to record on about 6 of these. The old discs I used were Memorex 16x (not UP to). I found one of my old discs just a few minutes ago, and popped it in. Its recording with no errors so far. So, this is a speed thing?
  • 4 Answers
Sometimes that error is due to dirt build up. You might try running a disc cleaner through. It helped mine.
Posted on Jan 28, 2008
6ya staff
SOURCE:
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
Will not record and also keep geting error nodisk
Did you try a disc cleaner? Maybe the lens is just dirty.
Jan 03, 2008 | Televison & Video
My RDR-GX300 Stopped loading & formatting blank discs
either a dirty optical pickup or a a bad optical pickup in the unit=pretty much has to be one or the other
Apr 07, 2012 | Sony RDR-GX300 DVD Recorder
When trying to record a home video VHS to DVD this is what I get. E-4 54040990 Cannot record on this disc. The disc is brand new.
Have you've tried cleaning the laser with a cleaning disc?
Failing this it may be worth removing the cover and cleaning the lens directly with a QTip and some lens cleaning fluid. Only use a drop and then wipe off with a clean dry QTip.
The other option is that you are using an incompatible format of blank DVDs. I've heard of people having problems using DVD-R & DVD-RW and although it is lised as being suitable for all types of recordable DVDs I belive you're best using DVD+R & DVD+RW.
The Manual states
Recordable disc
• We strongly recommend for good recording quality:
SONY DVD+RW 4x, MAXELL DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, TDK DVD+R 4x/8x/16x,
MAXELL DVD-RW 4x, MAXELL DVD-R 8x/16x
• Discs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+RW 4x VERBATIM DVD+R 8x
VERBATIM DVD-RW x VERBATIM DVD-R 8x JVC DVD-RW 4x MAXELL DVD-R 16x
May 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Won't record on blank disc.
Bulk disc that comes in cylinder case are some time faulty and loses quality because they packed on each other. The lens of the disc are sensitive so if disc is scratch or dirty will get error message "no read". Turn the unit off then unplug ac power cord for more than two minutes then reconnect and try disc again, if issue still exist purchase disc that comes in individual case.
Sep 15, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
EWR20V5 DVD Recording Error
The disc must be DVD-R with an R4.7 under the logo and they MUST be 4X or 8X specific .... the cannot be 1X to 8X or 1X to 16X or note up to 16X .... the disc box must state 4X or 8X ONLY .... and yes they are hard to find for sure.....
Aug 24, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Philips Magnavox MWR10D6 DVD Recorder Logo
291 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
