Question about RCA F36650 36" TV
RCA F366550 The problem stared several months ago the picture would start to shrink horizontally then it trend off by itself but I would be able to tern it on agene. 2 days ago it started to due the same thing but it tern on by itself it did it 3 times then staid off when I turned it on it came on but no picture only sound. SERIAL: D163C21SW CHASSIS: ATC113CA1
  • RCA Master
  • 5,138 Answers
Your hori out put is proably shorted,which means you have no high voltage, also your flyback transformer could bad.
Posted on Jan 27, 2008
Tv shuts itself off
pls check the a.c. cord is good,then check fuse of the unit if deffective need to replace it and check the horizontal output if is good or not.
Jan 11, 2009 | Sanyo DS27510 27" TV
Picture from 60" to 19" then gone.
The fluid is a fairly easy replacement. They just need to remove the CRT with the bad fluid and drain the old fluid and clean the CRT and then replace the fluid. The Shrinking is just a Vertical Deflection problem which is also an easy repair. A new Vertical IC and a couple Capacitors. In my shop it would run @ $200.00 to fix both.
Dec 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Ikegami pm 909 shrinking picture
The deflection current is dropping in both vertical and horizontal. This suggests a low B+.This can also be caused by a flyback problem. Check all the Caps in the HV section. If not, it's the flyback.
Aug 13, 2008 | Home Security
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
NO PICTURE HAS SOUND
When you say small do you mean shrunk up top and bottom as well as from side to side. You definitely have a deflection problem either horizontal or vertical.If the picture just shrunk top and bottom you have a vertical deflection problem. Do you have the service manual for your model? If not let me know and I will email you one. Describe the shrinking issue a little more and I should be able to give you some guidance.
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Toshiba TP50H95 No sound no picture
Sounds like a problem in the deflection circuits either vertical or horizontal. You may also want to check the solder connections in the tuner as they have been known to develop cracks over time. But the prior shrinking tends to say deflection problems.If I can assist you further please let me know.
Feb 03, 2008 | Toshiba 50H81 50" Rear Projection...
Mitsubishi ws-55813 horizontal hold
When you say horizontally, do you mean it collapse or it scrambles. Because the 2 are different problems. If you pictures shrinks or collapse then it is in the vertical circuit. and if it scrambles itself almost like you can see the picture but it is broken up over and over again, then this is video problems in video circuit. Need more info
Aug 13, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Shrinking picture
All symptoms indicate a problem in the vertical circuit,the first thing to look for will be loose conection on the vertical output IC,sometimes this IC goes bad completly and it needs to be replaced.If you are familiar with soldering electronics you can take care of it but if you are not too familiar you can play it safe and take it to a servicer ,it will be a lot less expensive than if they come to your house.Let Us know how it goes or if you need more information.
Oct 26, 2006 | Quasar SP-2722 27" TV
Picture Shrinks
It is in the power supply or I would guess most likly in the horizontal sweep section of the tV set. MOST of the time, if the power supply is going lower in voltage, the set will shrink in width,BUT will also shrink in vertical size. If this is not happening, then I would say it is in the horizontal drive circuit. This is not a circuit a user should be experimenting with, as this is the HIGH VOLTAGE circuit and can pack a mean punch! Please if the sets less the 4 to 5 years old you may want to concider an estimate or replacing the set. Its all up to you. GOOD LUCK
Oct 07, 2006 | Philips 8P6034 TV
RCA F36650 36" TV Logo
61 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
