Question about Hitachi 53SWX10B 53" Rear Projection Television
Part Cost I just had my Hitachi repaired and saw the part STK392-150 listed on the bill as $70. Out of curiousity I looked it up. This part is going for under $10. What's the deal?
  • 1 more comment
  • illuvial Jan 20, 2008
    Should make a complaint?
    To who?
  • illuvial Jan 22, 2008
    I called the shop and was told the chips are ordered from Hitachi. They are not generic.
    Anyone know if this is true or not?
    President:
  • 4,402 Answers
You should be asking where you got the chip from what the deal is... seems a little high ok alot high
Posted on Jan 18, 2008
How do i fix this dip line its model 57 uwx 20 b
Look like RG convergence is out , but it's hard to tell from the pic
if you can't correct it with the set up in " convergence " on the setup menu , then your Convergence chips are failing
if you handy with a screw driver and a soldering iron you can swap out the chip yourself since it's not worth taking to a repair shop
cost for the chips 65.00 -70 , you can get cheaper if you shop around
youtube
http://www.tvrepairkits.com/xcart/hitachi-57uwx20b-convergence-repair-kit.html
buy part
Feb 24, 2016 | Televison & Video
Picture shows red
The model listed and some models just before it had a red or pink area oval in shape (can be almost any shape) that is caused by the Optical light engine (not cheap part) being damaged by the heat from the lamp, unless its under some warranty not cost effective to repair, last one I saw was over 600 wholesale just for the part.
Dec 12, 2012 | Hitachi 60V710 60" Rear Projection HDTV
Hitachi 18v cordless circular saw need to know who can repair it.live in richmond va
Go to the Hitachi website, http://www.hitachipowertools.com/index.aspx, and under 'Service & Support' you can search by your zip code to find a service center near you. If it's the newer LXT line of tools it is now covered by a lifetime warranty so look for an Authorized Service Center to check on that.
Apr 24, 2012 | Hitachi Power Tools Saws
The screen has a red bloom in the middle when changing channels, also when watching a hockey game the ice looks yellow.
Your optical engine is bad. It will probably continue to get worse but it won't cause damage to anything else in the set. The part number will be UX***** depending on what model you have. (Asterisks denote numbers) Repair cost can exceed $850
Bill W
integrityhomeworx.com
Mar 21, 2011 | Hitachi Televison & Video
Looking for cost of replacement motor for skilsaw model 3400 13amp for 10" table saw and where to buy from? Also, is there a 15amp replacement motor that would bolt right in to replace?
i looked online at places I get parts from. Neither listed the motor as a part the had the aramature for about $70 and the field for about $35. Have you tried the reset button? also it may just need new brushes.(if you see lots of sparks at the end of the motor opposite the blade, look through the air vent slots it is likely the brushes, unplug the saw, and take them out and replace them HERE is a blow up ) the I would think that if the saw is well used and the motor has burnt out. It may be a lost cause. I am not sure what the price of this was new but you can get a reconditioned saw from Amazon for 135 bucks. And it is a 15 amp saw.
Dec 07, 2010 | Skil 10" Table Saw 3400
Poulan Pro Chainsaw chain tensioner is junk -- chain now goes from tight to falling off in 1 cut. Model PP4620AVX. Looking for more foolproof mechanism!
Hammy if you scream loud enough Poulan may foot the bill for this.
Poulan “PP4620AVX” IPL (exploded parts list)
We are going to replace this page 2; item 70
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AVX-545103410-952802169.pdf
Poulan “PP4620AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047502.pdf
Poulan “PP4620AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4620AVHD-Gas-Saw/75.PP4620AVHD-Gas-Saw.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 67; ChainBrake Assembly; $21.83.
You also need;
  • Item 68; Bar Mounting Nut; $0.56 each (need 2) and
  • “Engine Assembly” print; not illustrated; part number 545006011; Scrench; $9.75.
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 18, 2010 | Poulan Pro Chain Saw 46cc 20"
Boken shaft of old Craftsman skill saw
I have repaired many craftsman circular saws over the years and find that they share some parts with other brands. When sears drops a model number you must try to discover who made it for them. You did not list a model number, however when I need to identify a saw w/o the number I look at old part breakdowns and look on ebay for similar looking saws. Try and identify which manufacture made it for sears. Many were made by skill over the years so I start there. Once I find a good match, I check for available new parts. If not available, I check pawn shops and small tool repair shops for used parts, even burned out armature then have it rewound at www.eurton.com If you value your old saw take the extra time to look around, if not buy a good used saw at a pawn shop. I prefer Makita or Milwaukee good used about 40-70$; good used craftsman 20-30$, take a good look at the armature commutator and check that the arbor bearing is tight. Good Luck and email if you have questions.
Mar 30, 2009 | Craftsman Saws
Hitachi 55hds69
Loose connection..get a repairman to open it and secure the connections
Mar 07, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Screen Replacement.
find a phone number for hitachi and they will sell the screen to you directly for list cost some other places might try to mark up any prices.
Feb 01, 2008 | Hitachi 53SDX20B 53" Rear Projection...
Yelowing in screen
I contacted Hitachi about this problem and they were very cooperative with me. They agreed to replace the light engine. When I mentioned that I had done some reseach on the internet and saw that they repaced the light engine and covered the cost of labor for some other customers, they said that they would submit a request for the labor for the repair. As it turned out Hitachi covered the part and labor for the repair. I first contacted Hitachi in March 2009, By mid May the service-center recieved the part and performed the repair.
Mar 01, 2007 | Hitachi 60V710 60" Rear Projection HDTV
Hitachi 53SWX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
