Question about Baumatic 23 in. BDW13 Built-in Dishwasher
Water not heating
Upon installation the machine fills and goes through all cycles, however the water does not heat. any solution??
  • 2,039 Answers
You put the hose to hot water pipe cheers
Posted on Jan 19, 2008
Bosh dish washer has a plastic fitting for the water inlet looks like regular plastic not cpvc for hot water ,I was reading some of the question and answers and one say hot one says cold?
If the machine has only 1 fill hose, I would connect it to the cold tap. If you connect to hot only, the machine goes through its cycle too fast and wont wash as good. The machine stays on a wash cycle until it heats up the water. If you connect to hot water, it will do a shorter wash because it doesn't have to heat the water up as much. The shorter wash time, decreases how good the wash result is.
Dec 27, 2017 | Washing Machines
Hi my machine will fill with water then doesn't do anything for the whole wash cycle then will dran and spin but will not wash in the wash cycle
Hi, it could be your heater element is not kicking in and so its not heating up the water and not moving on to the next stage of washing. Best get the unit checked out.
May 03, 2016 | Washing Machines
Changing washing machine heating elemant
washers dont have heating elements, they use hot water from the hot water tank, most likely clogged screen at either end of the hot water hose, replace or clean screen(s) check for screen at water valve, bad,weak or burned solenoid on water valve, replace valve, reason wash cycle is long----- water restriction during fill and rinse cycles they are controlled by the water level switch
Jul 09, 2012 | Washing Machines
I have a Whirlpool washer. It will fill and run through the first cycle and then stop... What would cause this?
I would pretty much guess it's a faulty heating element. After the machine stops after filling with water and running a while to get the clothes wetit stops to heat the water. Listen carefully to hear the water heating up, it sound simular to an electric kettle. If this does not happen the program is unable to advance.
Apr 06, 2011 | Whirlpool Washing Machines
Whirlpool auto load not filling with water to wash, but will go to rinse cycle
There are 2 inlet valves 1 for hot water and 1 for cold. Sounds like your hot water valve is either faulty or the hot water valve to it is off. The machine normally fills with hot water as it doesn't have a heating element to heat the water and fills with the cold water to rinse
Feb 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
RE: F9 Upon startup the unit goes thru the normal cycles for making an expresso but, after the beans grind, little to nothiing is dispensed. The unit stops and the message is to fill water portion. I push...
Hi Bill
What happens when you do a tea ? (hot water only, NOT the steam button) do you also get little water ?
The fact that you are getting steam is good as there are 2 heating systems in the unit.
Have you ran the descaling recently (if you do not use filter ) ?
If you have or use a filter the problem is likely to be at the rear of the machine, however the back contents all the power and you will need to be happy to do some stripping down of the machine,
In the back you have the pump, valves, heater etc.
I am just about to draw up a flow chart of the water system inside the machine and have it published online (couple of days).
Are you happy to strip machine down ?
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | Jura Capresso Impressa F9 Espresso Machine
Run cycle goes for 2 hrs or more
In the last ten years the machines have been using a water heat feature. The water will heat roughly 1 degree a minute so depending on the installation and temperature of the incoming water, a complete cycle can be 90 min to over 4 hours.
Eric
Jan 12, 2010 | Kenmore Dishwashers
Cycle starts but water doesn't fill past heating elements.
I think that the problem is the water inlet valve if the machine is not filling at all.
If the machine is not filling to the correct level, it may be the float switch.
Apr 27, 2009 | Zanussi 24 in. DE6544 Built-in Dishwasher
Hotpoint Ultima WF860T
Alarm
code Description of fault User
code Effect
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dishwasher keeps running
The dishwasher should heat the water to about 50 C as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water and waiting for the water to reach the temperature. In your case it look like the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. Another possible is that the timer unit is defective (this is the worse case because of its cost !!!!)
Apr 10, 2006 | Baumatic 24 in. BFD60SS Free-standing...
Baumatic 23 in. BDW13 Built-in Dishwasher Logo
247 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
rich2481
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
