Question about Sony KV-27S42 27" TV
Video works when playing DVD, but not with Dish signal.
We have the exact same problem, exact same model.  Suddenly, audio with no video (when using Dish feed), but a DVD plays perfectly (audio AND video), so it can't be the tube!  Problem occurred when TV was turned back on after having been turned off.  Also hooked a different TV up to the Dish feed and it worked fine (audio AND video), so it's not a Dish thing.  What does that leave???
The set is a Sony Trinitron Color TV, Manufactured January 2001.
  • Anonymous Apr 07, 2008
    Sony KV-27S22 27" TV I have jumping lines at top of a normal picture,then picture goes to black ie loss of video. From your description my thinking there's either a problem in the tuners PIF output section or a part between it and the input of the large video IC. The video IC is probably ok since it will pass external vdeo normally.It's going to be cheaper just to use the TV's external A/v input and hook your satellite audio/video output using the same RCA type cable as you did with the DVD player. Of course if you want to use the DVD and satellite on the same TV you will need to buy a video switcher, connecting each of your products to an input (usually up to 4) and the output of the switcher (usually 1) to the TV's A/v input and setting the set for video mode all the time.
I have the same problem.I turned it off for 5 minutes then turned it on and off a few times.
And I hit it to, not recomended
Posted on Sep 06, 2008
Video no audio
Unplug the dish unit for 20 to 30 seconts an least, if you get to the settings screen select restore factory defaults.
Jan 22, 2013 | DISH Network Dish Satellite Tv...
Old TV. Model M79R. How do I connect a DVD player (only a player). The TV is connected to satellite signal (Dish) wired to the 2 UHF screws. I am not sure what or where to connect from the DVD player.
Your DVD outputs composite Video & and an Audio signal, subsequently you must have AV inputs on your set they are Red & White (Audio) & Yellow (Video) RCA Jacks. If you do not have these then you are a bit stumped. You may however get a RF Modulator, this takes the Composite Video & Audio signal, and converts it into a TV Signal that can be "Received" on a TV Channels.
I have included a link so you understand what I am talking about.
Feb 13, 2010 | Televison & Video
Sony DVD Player worked fine forever, suddenly gets 'No Signal' on
check the video is going from output on the dvd player to the input of the tv. Good Luck.
Nov 12, 2009 | Televison & Video
Just bought TV and connected with red,white, yellow and s-video connections. screen says NO SIGNAL. I have a satellite dish and dvd/vcr. the dvd/vcr image shows up on tv screen.
* Possible Problem *
It's not clear how you have each of the components connected to the TV, but you do mention that you used the "yellow" and s-video connections. Those are both video connections. The yellow is a "composite video" connection. Many TVs won't accept signals from both the yellow and the s-video connections at the same time. Usually one will override the other.
* Possible Solution *
Make sure the satellite dish is on and (hopefully) on a valid channel. Try disconnecting the s-video and checking the screen. If it didn't work, remove the yellow connection and replace the s-video cable. Check again.
If the problem persists, please explain how the TV, dish and the dvd/vcr devices are connected to each other (audio cables not relevant).
May 15, 2008 | Televison & Video
No output to Zone 2 from preout to 2nd power amp for second room speakers
OK, From what I am understanding is that you both are trying to uilize a digital audio source (HDMI cables are digital audio only) and hence this is the problem. You can only use an analog audio source (connection) to utilize the audio output to zone 2. A simple soultion is to use the analog audio in conjuction with the digital. Connect the digital (HDMI, Optical, Coax) to the main zone and the left and right audios to zone 2.
Dec 22, 2007 | Denon AVR-3803 Receiver
Dvd burner
Can you try just running a/v cable from your tv output to the inputs on the ilo, then whatever you watch on your tv you can record on your dvd burner. My new SDTV doesnt have audio out except Coax so this won't work for me on that tv. Why doesnt the newer tv's have audio AND video outputs???
Oct 30, 2007 | iLO DVD Recorder DVDR05
Digital Audio moved from TV/SAT to DVD/LD
Using the remote control, push the left arrow until display shows Coax1 (or 2, depending on your setup), then push the up arrow to set it to TV/SAT.
Conversely, depending on your setup, you can push the left arrow to display Comp1 (or2) then push the up arrow to set the correct video setting-- DVD/LD I assume.
Apr 09, 2007 | Pioneer VSX-D514 Receiver
Multiple video inputs
Unfortunately, you cannot use the connectors at the same time. The S-Video connector overrides the standard video connector. This is why they share common audio left/right inputs. If you could use them separately, they would each have their own set of audio inputs. (S-Video does not carry audio signals on the cable.) I'm assuming that you are connecting your Satellite as an input to your VCR, and then your VCR to the TV via a video connection. The VCR passes the satellite signal through unless you are watching a tape, then it overrides the dish signal. You have a few choices here: 1. You can connect the coaxial (RF) output from the VCR to the TV, and watch the satellite and VCR on channel 3 (or 4). You can then connect the DVD via S-Video, and watch it on "video". This is the simplest solution, and provides the best picture quality for the DVD (with this TV), but lower quality for the dish and VCR. 2. You can connect the DVD player via RF (if it supports that), watch the DVD on channel 3, and connect the VCR via video. This will make the DVD picture quality terrible. 3. You can replace the VCR with a combo DVD/VCR unit. You can then connect the S-Video out from the combo unit to the TV. This is a more expensive solution. 4. You can replace the TV with a model that includes more inputs. This is the most expensive solution, but will allow you to watch your DVD over component cables (very high quality) and VCR and dish over S-Video. Ironically, the obvious choice, connecting the DVD as an input to the VCR (as a pass-through) simply WON'T WORK. The signal put out by the DVD player is "copy protected" (using a system called MacroVision) which the VCR will refuse to play, even as a pass-though. Best of luck with this. Given that you are trying to make this all work without replacing equipment, I recommend option #1, until you decide to break down and buy a shiny new HDTV. They are coming down in price every week, but only you can decide when the time is right.
Mar 22, 2007 | Sony KV-32S26 32" TV
Sony KV-27S42 27" TV Logo
66 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
