I have a GE wall oven which was probably manufactured in 1996 or 1997. It is giving a F5 error message while turned on. The magnatron was replaced in 2004 because of error messages. What does F5 mean?
Thanks -
[email protected]
SOURCE: F2,F5,F7 message
MAYTAG
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F1
Defective touch pad or membrane
Replace touch pad or membrane (usually the touch pad)*
F1
Watchdog on board
Replace touch pad or clock assembly (also called the ERC)
F2
Oven too hot
Replace relay board (if present) or bad oven temperature sensor
F3 or F4
Open or shorted oven temperature sensor
Replace oven temperature sensor
F5
Hardware and watchdog circuits disagree
Replace clock assembly (also called the ERC)
F6
Missing AC signal
Check for proper voltage
F7
Function key shorted or stuck button
Replace touch pad or clock assembly (also called the ERC) or un-stick button
F8
Analog/Digital supervisory
F9
Door latch supervisory
Check door lock circuit or replace clock assembly (also called the ERC)
F0
Function key stuck
SOURCE: E1 F5 Error on Whirlpool Accubake Oven
The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
SOURCE: The F5 error code?
I unplugged the oven and it cleared the code and was able to self clean the oven.
i have a ge profile wall oven model #jtp18bod1bb with code f5 oven beeps & shuts down
