Question about Avermedia AVerKey iMicro (58686)
I am using an AverKey iMicro and the picture on the television is black and white. When it was first connected everything was fine.
  • msjacobs Aug 20, 2008
    How do you check the region code?
  • 1,601 Answers
Verify that your region setting is correct, ie USA is NTSC.
Please let me know if this works for you.
Posted on Jan 18, 2008
I was trying to connect my ps2 with Panasonic vieara tv but picther is in black and white and no sound
A black and white picture suggests you are trying to use a composite video input but the TV may be NTSC format while your game is PAL, or the other way round. Use a game with the correct format or use the separate RED, GREEN & BLUE inputs (may require a different type of lead).
Jun 01, 2016 | Panasonic Viera TH-42PX80U Plasma TV
Black and white picture on wii
Double check your connections, may I ask which inputs are you using?
Feb 23, 2013 | Sanyo 42 in. LCD TV
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
I just bought a Westinghouse LED TV. When I hooked up my dual DVD/Video combo the picture is black and white. What did I hook up wrong??
It sounds like you may have connected the dvd/video combo to the wrong spot on the television. The yellow wire cannot be placed into the green hole. You'll get a picture but it will be in black and white. You can only connect these yellow, red, and white composite wires to a component input spot on this television in order to get a color picture.
Aug 21, 2011 | Televison & Video
Plugging red to red, white to white, and yellow to SPDIF (black) and got no picture with sound. Plugging red to red, white to white, and yellow to green and got black and white picture with sound. How...
First you need a component cable to solve your problem.Since you have not mentioned what device you are connecting to your TV, I''ll assume its a DVD player or a settop box.There is a Red and White audio sockets + Red / Green / Blue component video socket. Just make sure you connect the corresponding two sets of jacks at both end of your TV & DVD player and everything will work. bobhifi_21.jpg
Mar 27, 2011 | Philips Televison & Video
Is there a way to get audio to my tv through this device?
What you need is a audio Y splitter such as a Belkin Audio Y Cable Splitter You can pick one of these up at your local radio shack.
Plug the stereo jack into the audio out on computer (green colored port) Then plug the red/white ends to the matching ports on your tv. Make sure you use the same audio ports that the video from the iMicro is plugged into.
Mar 01, 2011 | Avermedia AVerKey iMicro (58686)
Picture black & white menu color #26mf231d/37
I have the same problem too. Need a fix. This tv isnt that old and is not used that much. does not seem to be the cables or cable box. the menu has color to it but the channel picture is in black and white, flickers a bit, and seems to be in a very large pixle form. it this able to be fixed? Please Help.
Nov 10, 2009 | Philips Magnavox 27MS343S 27" TV
No color only black and white picture
one of your color tube has gone out on you.
Jan 25, 2009 | Hitachi 43F300 43" Rear Projection...
DVD hookup to LCD monitor only appears in black and white!
I have a RCA flat screen television and my dvd player when hooked up is in black and white. How would i fix this and if so plz be more specific then these other people.
Jan 02, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Avermedia AVerKey iMicro (58686) Logo
345 people viewed this question
Top Avermedia Televison & Video Experts
Alun Cox
Are you an Avermedia Televison and Video Expert? Answer questions, earn points and help others
