Question about RCA D52W19 52" Rear Projection Television
Intermittent Sound Hi..My RCA D52W19 has a problem with the sound .The problem only occurs on two specific channels when they are broadcasting the same program. At first I thought it was a problem with my cable provider but other sets in the house do not do this. It sounds like about every 8th word cuts out.There doesnt appear to be any problem on any other cable channels or when playing DVD's.I also have a satellite dish and experience no problems on any of its channels. Any ideas??
  • gmc1 Feb 11, 2008
    Thanks for trying.....SAP was not selected...Would selecting it help??
  • 934 Answers
Check the audio menu and see if you've selected SAP (Second Audio Program) and if so unselect it..
Bill
Posted on Feb 10, 2008
  • William Rayburn
    William Rayburn Feb 11, 2008
    Selecting might, it couldn't hurt to give that a try, but you would have to de-select it when changing to another channel...
    Bill
Hi I pressed the wrong button turning the TV on, now I have no sound and can't get it back. please help.
SAP (Second Audio Program) may be turned on. This used to be a widespread RCA problem maybe caused by incorrect conversion of analog signals for viewing as phony HD images. Costly class action lawsuits addressed the problem in USA. Most of the specific equipment causing the problem used by broadcast/production/satellite industries was either adjusted correctly or replaced. If the problem re-occurs, it may caused by specific TV channels or programs that you watch. Codes inserted in the signal are incorrect and confusing the RCA TV Guide and audio processing circuits. The error causes SAP to be incorrectly selected as default for all channels.
Remedies:
Change audio settings in customer adjust menu to Stereo from SAP. Sometimes the On screen TV Guide set-up must be cleared of location, etc., and set-up again.
Sometimes it is difficult to set correctly. Unplug TV for 12-24 hours and TV may reset to default stereo setting instead of SAP.
This was an active Class Action legal issue 10-15 years ago in the USA.
easyab
Feb 23, 2011 | RCA Televison & Video
Bought a rca surround sound system an hooked it wks great but cant get surround sound on my cable chanels just when watching a dvd...what do i need to do?
You need to make sure that the Audio in the programs you're watching are broadcast in Surround.
You can also select a channel that is broadcasting in HD, and Digital Audio to see if that helps
To save money and bandwidth, they'll only broadcast the audio in the Analog format.
Hope that helps.
Please don't forget to rate:)
Dec 22, 2010 | RCA Audio Players & Recorders
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
TV channel sound from a different channel
I just unplugged the tv from the power source and disconnected the cable connection and then reconnected them back after sometime. The TV started auto programming after turning on and that resolved the problem.
Oct 18, 2009 | RCA Televison & Video
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
D52W19 RCA 46 inch t.v.
my RCA D52W19 52" rear projection TV will not power up ( turn on )
Nov 17, 2008 | RCA D52W19 52" Rear Projection Television
Channels wont come in
sounds like the tuner is shot...mine is. easy cheap solution is to use either a cable box or a vcr as your tuner (hook it up to the a/v input if channels 3 and 4 are currently affected)
Jul 27, 2008 | RCA D52W19 52" Rear Projection Television
Tuner problems
it sound like the tuner to me here is rca part# for the tuner 264658 abour $70.00. good luck
Dec 26, 2006 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
