Question about Zebra LP 2844 Thermal Printer
ZUD Print error Under temperature
Error message "ZUD Print error Under temperature" whenItry to print label.
  • 57 Answers
Continue printing while the print head reaches the correct operating temperature.
Posted on Apr 24, 2008
We have an HP 2015n printer with an error code of 10.1000. Can you please tell me what this code means? Thanks
10.1000 Black e-label missing error Error message 10.1000 supply error alternates with Reinstall c00381084.jpg with a ? under the Black print cartridge gas gauge Description The black print cartridge or print cartridge e-label is missing. Action
  1. Install the black print cartridge.
NOTE: If this error occurs upon initial power-up on the printer, remove all cartridges to check for the orange packing tape. If present, remove it before reinstalling the toners.
Nov 10, 2010 | Computers & Internet
When printing a label on brother QL-1050 printer comes up with error "Either BOF or EOF is true or the current record has been deleted Requested operation requires a current record" I have removed...
I solved this problem by pressing "Control N" to bring up a new label. Works fine that way.
This is the answer Brother gave when I called them:
Description of Problem 100000003722
When I click print I receive the error message: Either BOF or EOF is true, or the current record has been deleted.
Description of Solution 200000004488
This error message occurs when you print a label that has no record in the database table.
To avoid this error message, click on Database menu, select Create New Record.
Oct 09, 2010 | Brother QL-1050 Label Printer
10.00.00 supply memory error
The 10.00.00 SUPPLIES MEMORY ERROR is based on the e-label. To clear the error, do the following:
NOTE: If the error occurs, it should appear at beginning of life, causing the error message after first installing the cartridge.
Turn the printer off and on to clear the message.
Put in the old catridge and see what happens.
If OK put in the new one again.
Verify that the print cartridge is a genuine HP cartridge.
Check that the E-label reader is functioning correctly.
Check that there is contact between the E-label chip on the print cartridge and the E-label reader on the printer.
To verify this contact, insert a new print cartridge.
Remove it again.
Check for scratches on the e-label chip and on the cartridge.
If contact is being made, replace the print cartridge (part number: Q2610A).
If contact is not being made, check the toner guides to see if they are in the proper position, or that the cartridge is not damaged.
If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
Turn the printer on again.
If the error does not clear, turn the printer off and remove tray 3.
Turn the printer on and verify if the error clears.
HP has recently discovered that a 10.00.00 Supplies Memory Error can occur when Tray 3 is faulty.
May 06, 2010 | HP LaserJet 2420 Printer
Paper jam error message
This problem is a detection problem, due to a bad sensor selection or incorrect label size.
If the labels are white labels with a separation between each, select TRANSMISSIVE. If the labels are preprinted, select the TRANSMISSIVE PREPRINTED LABELS and set the threshold doing this.
With the printer in ONLINE, press PAUSE once, the message PAUSE appears in the display, press and hold on the PAUSE key, TRANSMISSIVE is displayed, release the key and press PAUSE until labels starts to feed, let feed some labels (5 or 6) and release the key. Press Restart and start to print.
Dec 08, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
Zud - print error - under temperature
Try using the latest zebra printer driver. The ZUD driver has been superceded by the latest Zdesigner driver which works in Zebra Designer and any windows application
Jun 09, 2009 | Zebra LP 2844 Thermal Printer
What does 10.0002 supply error mean?
10.0002 Magenta cartridge e-label error Error message 10.0002 supply error alternates with Reinstall c00381084.jpg with a ? under the Magenta print cartridge gas gauge Description E-label cannot be read or print cartridge is not properly installed. Action
  1. Open the front cover of printer and remove the toner cartridge exhibiting error.
  2. Inspect the print cartridge to ensure the e-label reader is attached to print cartridge and is not damaged.
  3. Inspect the inside of printer to verify the e-label does not have any product packing tape still attached.
  4. Inspect the e-label reader to ensure the gold contact points are not damaged or bent. Also inspect the black plastic on e-label reader to ensure it is not bent or broken.
  5. Reinstall the print cartridge.
  6. Power cycle the device.
  7. If reinstalling the print cartridge does not resolve the issue, replace the print cartridge.
  8. If the problem continues, contact HP Customer Support Center for technical assistance
Dec 03, 2008 | Office Equipment & Supplies
ERRO
The following solution was found at;
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=446153&prodTypeId=18972&prodSeriesId=446153&objectID=c00314875#A9
Cut & pasted here it is;....
10.0003 Yellow cartridge e-label error Error message 10.0003 supply error alternates with Reinstall c00381084.jpg with a ? under the Yellow print cartridge gas gauge Description E-label cannot be read or print cartridge is not properly installed. Action
  8. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Nov 28, 2008 | HP Color LaserJet 2600n Printer
I have a Pixma MP500 Canon printer. The error message coming up is error message # 5200. This is not an error message I can fix. It is not listed in my User's Guide. What is the problem?
Hi affrench,
Your problem in all likelyhood is print head temperature. The temperature at your print heads has exceeding the allowable parameters set forth by your software and manufacturer. If your printer is under heavy use loads this could be why you are getting this error code. Take it easy on the old boy, after all its only a machine, lol. I hope this helped.
Thanks for using FixYa.com
Sincerely, cyyyd7
Oct 09, 2008 | Canon Office Equipment & Supplies
Zebra LP 2844 Thermal Printer Logo
793 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
