Question about Canon FAXPHONE L80 Laser
CENTREX SYSTEM, DIAL 9 FOR OUTSIDE LINE ? WE NEED A FAX MACHINE!
WHICH FAX MACHINES WILL WORK WITH THE CENTREX SYSTEM
  • 59 Answers
All faxes will work on a centrix system where you must dial 9 first then the fax number. For example, if you are calling from an office the most reliable way in most cases is to dial 9 pause then the fax number.
Posted on Feb 20, 2008
    Scholar:
  • 159 Answers
Don't know anything about Centrex
Posted on Feb 07, 2008
  • 63 Answers
Not many!
You should go to your nearest fax machine supplier who will give you a list of ones which are already programmed with the centrix system!
Hop this helps - Josh Howard
Posted on Feb 02, 2008
Why did my fax machine suddenly stop working?
Check that the memory is not full. Also, make sure a setting like (auto-dial 9 for outside line) is set incorrectly.
May 17, 2015 | Office Equipment & Supplies
How to receive a fax--i can send a fax but not receive
Not sure what this has to do with a 7630 phone, but you forgot to mention if the fax machine rings when a call comes in and if it's set up to answer on incoming calls, or is it just not ringing at all.
If the call goes out, dial 800-444-4444 and double check the line the fax machine is on. Make sure you're not dialing "9" to get an outside line, and if it happens to be truly on a TDA phone system, then the jack you're using has to be programmed to ring.
Carl
Jun 23, 2011 | Panasonic KX-T7630 Corded Phone
When dialing number it is giving a "wrong number" signal
As you said, the set up is either trying to dial a "9" or other number to access an outside line before dialing your destination number. You will need to get into the menu and delete that command. After that, you should be able to dial out.
Remember to have the fax set to "FAX" not "TELEPHONE" to send and receive automatically.
May 18, 2010 | Brother FAX-1020e Plain Paper Thermal...
I have a panasonic hybrid phone system and would like to connect a fax machine, when I connect the fax to the jack, I dont get a dialtone but it goes to the intecom line. The same happens if I connect a...
Hello, you can solve this one of two ways. Try pushing a 9 when you get intercom line, you should get an outside line. So when you want to send a fax, just remember to push a 9, get outside dial tone then dial your number. Or, the second option would be to program that extension jack to auto select a line when going off hook. That will take a manual and some additional guidance. Okay, so thats for making outgoing calls. When it comes to incoming calls, you need to find out what extension the fax is connected to. You can do this by dialing another extension that has a display from the fax machine and see what intercom number comes up on the phones display. So once you know the extension number you can do one of two things. You can leave the fax off since it will most likely ring when any call comes in your office, and only turn it on when receiving a fax. When you answer the fax call on one of your other phones, and hear the beep beep beep, merely push transfer and dial the fax machines extension. That will transfer the incoming fax call to that extension and the fax machine provided you have it turned on. The other option is to break out the system manual(not user guide), and program the fax machines extension to only ring on the line you want it to, say your last line and leave the fax machine on and give out that specific number for faxes. But you do run the risk of your call traffic being heavy, incoming calls rolling over to that line or someone calling that number directly and getting the fax. I think I covered everything I can with the limited information on your application, so I hope that solved your problem.
Sep 17, 2009 | Panasonic Advanced Hybrid w/Back-Lit LCD...
Having problems with long distance fax transmissions - receiving number not receiving fax. Fax machine: Brother MFC-8220.
Is the 1 placed infront of the number, is the line part of a PBX system requiring to dial a 9 to get a outside line.
Aug 13, 2009 | Brother MFC-8220 Fax
Need to know what bod rate is on my fax
older fax machines used a 9600bps baud rate, meaning a transfer rate of 9600 bits per second. a Bit being an 7th/8th of a byte. The newer machines can transfer at 14400bps, which older machines can not read, as its too fast. thats why they asking the BAUD rate.
Aug 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Samsung 816 power outage dailing an outside line
First thing you should verify a dial tone on the fax machine. (use any analog phone)
If you have dial tone, press 9 and then a number
Second is it conected through tel. system? (did it have an internal extension) and there is no dial tone then your analog port may be fried. Call your telephone vendor. He should be able to help you.
You can purchase a manual for about 10 dollars
Email your system model number to sales at aaa-avad.com for further instructions
Mar 31, 2009 | Samsung Prostar 816 Phone
Answering machine not working
Open your TalkSwitch Management Software.
Go to Local Extensions/Fax
Select the extension you are using for the fax.
Click on additional settings under the activate extensions section
On the direct Line Access Tab put a check mark in the check box for "Use Direct Line Access on:" Select your Hunt Group or the number you have to dial to get an outside line.
This will force this extension to not have to dial 9 or whatever number to get an outside line for dialing out.
Jan 25, 2009 | TalkSwitch CT.TS001.124001.US...
Toshiba strata dk 280
it may be setup to block outbound calling, remember also, you have to dial a 9 to get dial tone on a centrex line, so in this case if your phone system is setup to dial 9 as a line access code you will actually have to dial 99. hope that helps
May 13, 2008 | Toshiba Strata PT-390 Corded Phone
Canon FAXPHONE L80 Laser Logo
153 people viewed this question
old marine
old marine
