Question about Philips Magnavox 27MS343S 27" TV
Can't turn subtitles off
I cannot turn the subtitles off in my TV, the problem is that I do not have it's original remote control, so I am using a universal type one.
So how can I use that remote to turn subtitles off, or what other optins I have, when I go to MENU, there are not options for subtitles.
  • 12 more comments
  • Anonymous Jan 20, 2008
    I have tried everything to remove the subtitles on my screen, but they won't go away!!!! It is driving me crazy!!! Also,unfortunately when I was given the tv there was no remote, so I went out and bought a universal remote. The universal remote doesn't give you a way to get rid of the subtitles. I have no idea what to do they are driving me nuts!!!
  • Anonymous Jan 23, 2008
    I have the exact same problem! What the hell!
    I just had this happen too. I have a universal remote as well, but this just happened on Monday, somehow i pressed two buttons together i guess, and now i can not get the closed caption / subtitles off.
  • Anonymous Feb 05, 2008
    yeah this shit is pissing me off... I cant get them to turn off and it is making me very angry
  • Anonymous Feb 13, 2008
    my subtitles won't turn off, but I DO have the original remote. No matter, they come and go, and it's getting more frequent.
  • strahan Apr 01, 2008
    I HAVE THE ORIGINAL REMOTE AND THIER IS NOT A SETTING TO TURN OFF THE SUBTITLES WHEN YOU GO TO MAIN MENU HOW CAN I GET THE SUBTITLES TO GO OFF
  • Anonymous Jun 08, 2008
    menu button
  • ktend Aug 16, 2008
    I've tried every solution to no avail..... any other suggestions out there.... pleeeeez these subtitles are really starting to **** me off!!!!
  • Anonymous Sep 05, 2008
    I cannot turn the subtitles off in my tv, the problem is that I do not have it's original remote, so I am using a universal type one.
  • Anonymous Sep 07, 2008
    well i steped on my universal controler and it turned the subtittles on the tv some how and now i can take them off.
  • aldebaron350 Sep 09, 2008
    The Closed Captioning(CC) (subtitles to some) is turned on my magnavox TV and I would like to turn it off.
  • Anonymous Oct 17, 2008
    my magnavox tv has the subtitles turned on it is an old tv is there any way i can turn off the closed caption using the menu on the tv
  • Anonymous Oct 23, 2008
    i cant remove the st
  • samphantom Feb 18, 2009
    My TV is a Mitsubishi CS-26201C and I bought it used but with no original remote control, the TV has CC activated and I can not get rid of this annoying feature, I bouth a universal remote control Philips PM335 with no success, any idea on how I can get rid of it?
    Thanks
I want to thank whomever suggested the following...it works. I had been trying for days. Here is the solution:
Turn off the cable box and hit the menu button on the universal remote. The screen with the closed caption selection appears. Scroll down to the line regarding subtitles and turn it off.
Posted on Aug 17, 2009
  • 2 more comments
  • hardycath
    hardycath Jun 29, 2012
    You are my hero! I FINALLY have no captions blocking the bottom of my screen! Thank you soooo much
  • mirfer4
    mirfer4 Dec 13, 2012
    Wow thank u so much. I did exactly what u said. Turned off cable box and pressed closed caption off. Wow it was driving me crazy. I got a big smile on my face. Thank u tanknu
  • mirfer4
    U r the best
  • mirfer4
    My hero 2
For digital TV this is a feature of the satelite or cable box, not the TV itself. On the box remote press Menu, then go to Language, then find Text Language and select Off.
Posted on Apr 05, 2008
  • 5 Answers
If your universal remote has a "shift" button. press it once then try pressing the number 1. This worked for me on a phillips tv with a GE universal remote. If that doesn't work try the shift button with every other button on the remote. That's how I found this trick out :)
Posted on Jul 25, 2009
OK, this solution works if you have the original remote. Press the "cc" button until you see "cc mute" displayed on the screen. Then press "mute". The tv will now only display the subtitles when the "mute" button is pressed.
Posted on Jun 14, 2008
Using a Philips universal remote and a brief prayer, press the "PIP" button, and then make the "CC off" selection.
Posted on Jul 02, 2008
  • scarycharact May 27, 2012
    omg i love u ive been trying everything and i kept hitting PIP said a prayer and it worked thank you so much ur a lifesaver love Minda
Mediaspec you are the best! We were having this problem with Verizon FIOS. Using the Verizon remote I pressed PIP and then the CC. Each time I hit the CC it showed a different option, CC1, CC2, CC Mute and CC Off. THANK YOU mediaspec!!!!!!
Posted on Aug 24, 2008
  • libby love Nov 15, 2010
    OMG! Thank you! Thank you! This really works! My husband is the technology go to guy when we need help well he is deployed right now so I was so glad to find this! If I hadn't, we would have been watching sub-titles for the next several months until he returned!
If you have FIOS, you first go to menu, then you go to settings, then accessibility, then (CC)closed captions, and make sure that its off.
Posted on Feb 16, 2009
Hit shift 1 shift 1 until cc is off
Posted on Dec 09, 2009
I have a Magnovox 20MT1331/17 tv. i dont have my original remote, i have a universal cable (comcast) remote. i found by pressing the red "help" button located between the vol/ch keys it would cycle thru the cc options. hope this helps.
Posted on Jul 29, 2010
#12 Thank you It worked !!!!!! CC was on way to long !!! Drove me crazy
Posted on Jun 20, 2010
  • 43 Answers
Sorry guys but these t.v.'s need the orginal remote to use these functions.
Posted on Jan 31, 2008
  • dianei518 Sep 21, 2010
    I have original remote and there is no cc button, how do i shut it off????
I had this problem too, I have a RCA universal remote and i just played around pressing 2 buttons at the same time, i finally found that holding the enter button and pressing volume buttons changed the subtitles on and off. FINALLY after a month of having the subtitles on!
Posted on Jul 27, 2008
  • ashurst_3 Jan 08, 2011
    hi ca not believe i thought this problem was with the tv remote, and it was the cable remote,price guide select settings, then select change disply and audio settings, select subtitles when available and select off, how simple.
    New Friend:
Just had the same problem !
Go to menu and go to retune and find first time installation and press ok. After a few minutes of waiting for channels to retune and settings subtitles will be off ?? ?? ??
Posted on Aug 30, 2016
If you have a Cable TV remote (mine's from Time Warner) find the PIP section. Be sure it is in the TV mode. Then press the ON-OFF button until CC is off.
Posted on Oct 18, 2008
They do not need original remotes any phillips/magnavox universal remote will work to get the cc off.
Posted on Aug 21, 2008
HOLD IN THE INFO BUTTON AND THE PAUSE BUTTON AT THE SAME TIME ... for the universal remote (:
Posted on Apr 03, 2008
  • AshNeedsHelp Mar 09, 2012
    Do I wait for the red button to flash a certain amount of times of something? I've tried this option
    Problem Solver:
  • 4 Answers
Depending on how old your TVs are, perhaps you can write the maker of the TV and ask how much the remote control would be and have them send it to you. I was having trouble big time with this very annoying feature. I went back to the TV remote control and saw a button marked "CC" on it and pressed that and lo and behold! I got rid of the pesky closed captions!! Look for the "CC" button on the TV remote control.
Posted on Dec 30, 2010
Solution #12 work for me, thank you so much. I was about to destroy my t.v, those subtitles were driving me insane.
Posted on Apr 06, 2010
Has anyone noticed this exchange is ridiculous? Why have the people who design our TVs and access systems made it so difficult for us to get a whole lot of words we don't want from clogging uop the screens we pay them to put pictures on?
Posted on Mar 30, 2010
If you have a cable tv remote, find the PIP area. Hit the on-off button until CC is off.
Wat
Posted on Dec 03, 2009
Hello, I cannot figure out how to use subtitles on
Subtitles are integral to program material so you probably are wanting to enable closed captioning (CC). If your Harmony remote control does not have a CC button, go to the initial set up procedure for your TV and enable the feature.
Nov 17, 2017 | Televison & Video
Subtitles on tv no remote to get them off cant get code for a new remote model no 3241ts
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Mar 05, 2014 | Televison & Video
Polariod P40LCD12 reset
I personally have had the same problem with Universal remotes. The best solution is to buy the correct remote. I would first call the manufacturer to see what they would charge you for a new one. Then ask if they sell refurbished ones. Also check online for an OEM remote. You could probably get one for less than the universal remote.
Jan 04, 2014 | Polaroid Televison & Video
How do I turn off the subtitles?
go to MAIN MENU, and see the audio section look for closed caption and turn OFF.
God bless you
Oct 31, 2013 | Westinghouse Original RMC01 TV Remote...
Is there a way to access the subtitle button on a philips dvd player using the chunghop RM-88E universal remote control? Please help :(
Aren't you trying to select closed captions (CC)? If so, turning off the TV sound will cause closed captions to appear after a brief pause. Naturally, your TV has to be capable of doing this
Nov 02, 2012 | Televison & Video
Cant find subtitles on my one for all urc 7140 remote control
Universal remote controls might not work for all functions of a TV which is supposed to be. To get all functions, you must buy an original remote control for your TV brand.
Oct 22, 2012 | One For All URC 7740 Remote Control
How to take off subtitles
That is very unusual. Subtitles come from the television provider to the satellite or cable box, so that is where it turns off from.
Jan 29, 2018 | Televison & Video
I lost the remote to my Hitachi TV and I now can't
Buy one universal remote control, and set it with your TV. It will be best. If you want to get its original remote control, you have to contact the nearest authorised service center for Hitachi.
Want more details about selecting a substitute universal remote control? Check the setup codes for Hitachi, and buy one universal remote control, which has setup codes.
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Check associated ads too. Sometimes, it might help you.
May 29, 2012 | Hitachi Televison & Video
How to control sony str-dn1010 with RM-VL610
There are setup codes to synchronise the remote control with TV. You should do this. Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help
You can get al details about how to synchronise upur newly bought remote to your TV from here. Pull up older posts.
May 17, 2012 | Universal Remote Control Televison & Video
Linhdang2918i dont know what to press to turn on english subtitles with my logitech harmony 600
Hi.
Controlling subtitles with the Logitec Harmony Remote Control is exactly the same as controlling any other action. You just need to set up the Harmony to send the correct command/s, as follows..
- First it depends what 'Device' (AV component) puts the subtitles onto the screen, so you need to check the instructions for that device.
e.g. if that device is a TV, then check the TV's original instructions to find out what menu item is involved, or what button sets the English subtitles.
- Next, if the example above applies, look through the Harmony 600's Device page for the TV and see if you can identify the corresponding control buttons. If they are not present already, then teach the commands to the 600's 'Device' buttons for the TV, using the TV's original remote.
- Finally look in the Activities 'Customize Buttons' page to make sure that some buttons are configured to send the commands you need. If they aren't, or if they are not available, then program those instructions into the 'additional commands' for the relevant Activity/Activities.
If several button presses are needed then you could possibly even 'Add a Sequence', in the relevant 'Activity/s' page/s to do the job, and call it something like 'EsubSeq'
Regards
Chas
May 24, 2011 | Logitech Harmony 600 Remote Control
Philips Magnavox 27MS343S 27" TV Logo
26,170 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
