Viewsonic VPW 450HD
Hello from Germany,
can you tell me where I find the Logic Board Assembly Part#:NA18106-5006
in this TV? Do you have a picture from the technical manual concerning this part. I bought this part in the US, opened the TV, but I cannot find ths part.
Thank you!
Dieter
  • patriotbier Jan 18, 2008
    this address ( I tried ntid, too ) does not work.
    Dieter
  • 4,102 Answers
Hi you could try looking here as this is the site i use you might need to register with them to get the info
http://www.download.ntld.co.uk
this should help you
if its not ntld try ntid
Posted on Jan 18, 2008
    Genius:
  • 1,067 Answers
  • nick helpap
    nick helpap Jan 18, 2008
    proably buy the sound controllers in behind that area snaped up in by speakers
  • nick helpap
    chip creep" caused by thermal expansion/contraction. I took my unit apart and reseated all connectors and ICs that weren't soldered in and put the unit back together and now my unit is working again!
My Viewsonic VX2255WMB mod.# VS11659, when I start my computer and turn the monitor on all I get is a white screen, no text, nothing I do will display anything, is the monitor worth fixing??
The cable between the logic board and the LCD panel may have come off, or the board (T-CON) on the LCD panel failed, or the LOGIC board is not sending 5vdc to the T-CON board.
Repair shop will charge you around $100 plus parts.
Example of failed LCD panel assemblies: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 27, 2011 | ViewSonic VX2255 Monitor
Viewsonic VPW450HD Plasma
Did you try unplugging the TV from the power for a few hours?
Dec 25, 2007 | ViewSonic VPW450HD 42 in. HD-Ready Plasma...
White screen only
Check the ribbon cable between the logic board and the T-CON board, or the T-CON board is bad which means you will need new LCD panel, or the logic baord is not feeding the 12vdc to the T-CON board.
Apr 06, 2011 | ViewSonic VG2030wm LCD Monitor
VIEWSONIC PJD5111 SHOWS VERTICAL LINES
Hi... Projector show vertical lines... Issue in your logic board filter's missing on logic input board check for fail signal on video input logic board,,, check input connector for broken pin inside connector... also check capacitor & resistance arround video logic processor, possibility of over heat conponent
Oct 25, 2010 | ViewSonic PJD5111 Projector
I have vertical bars on screen
The T CON board of the television is bad, you need to replace this
The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
This is the interface board that talks to the Logic board and the LCD panel to produce pictures on the screen. White/gray glowing screen when it fails or not getting the voltage from the logic board (the 5 or 12vdc is supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
Common failures:
Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
Blown surface mounted fuse.
No pictures, very dark screen almost like there is no backlights.
Hope this helps........
Jul 30, 2010 | Sony KDF-E55A20 55 in. LCD Television
We are having SAMSUNG LA37R81B tv at home its showin blurred picture we asked repair man he said we need the tcon board number so that we can buy we now need your help
it possible that the problem is the the TCON board, you can try websites Shopjimmy.com,Ebay.com to buy a refurbish board for the replacement.
Also note that
Common failures:
Hope this helpout..
Jul 30, 2010 | Samsung Televison & Video
Hello my n71s has been lit white screen and no menu buttons work I can turn off. I tested on other computers and with various resolutions even in safe mode help
When you have white glow and no pictures, then more likely the the LCD T-CON board (part of LCD panel assembly) is not getting 5vdc feeding it, it can be blown fuse on the T-CON board or the logic board is not feeding the 5vdc to the T-CON board.
You need to check the power supply and the logic board first for bad caps (leaking/bulging top).
Please see my pictures here:
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 15, 2010 | Hyundai Electronics ImageQuest N71S 17"...
Viewsonic vx2235wm has a white screen. What is the problem?
If you have white glow on thescreen with no pictures, the problem can be the LCD panel controller board (part of the LCD screen) is not getting the 5v from the logic board. See pictures of failed VX2235W for guide as to what to look for first, otherwise you will need new LCD panel.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Mar 29, 2010 | ViewSonic VX2235WM Monitor
No picture on left side of screen and bad picture on right side.
Hello:
Have the Digital board and logic board replaced. the most common problem will be the logic board assembly. Altho the Digital board can also cause this problem. Try taking off the back and making sure the LVDS Cable is connected tightly to the logic board assembly and the panel, (Scrn), The LVDS Cable will look like a small wire harness with two metal clips on each end make sure it is secure, try disconnecting it and reconnecting it again.
Jan 13, 2010 | Philips Magnavox 42MF521D/37 Television
Have parts for Viewsonic VPW-425 42"
If these are used parts or from a scrapped set, buying used parts would be a very risky investment.
Jerry G.
Apr 13, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
