Question about Denon AVR-3300 Receiver
AVR-3300 Static and Sound Loss
I have had this receiver for about 10 years now (same one my father has, of which he has no problem of course), and about a year ago it started to make static noises (crackling also) and would start to loose sound.
The input does not matter and also the sound output (stereo, DTS, Dolby, 5 channel). I can literally type the front of the receiver (no harder than a flick) and the sound will come back on for a short period of time.
Also, I took the casing off and noticed that the fan is not running which I assume is not good, but that aside, whether it is 3 minutes in or 3 hours in the problem still persists....any ideas? thanks
  • 1 more comment
  • barry-g Apr 20, 2008
    i am having similar problems with my 3300. i have lost all sound out of my digital connections (analouge works fine) does anyone have a solution please?
  • dglozic Dec 12, 2008
    Same problem here - the sound would be OK for a while, then it would go away. Tapping the box on top restores it. Sometimes the sounds comes back on its own (no tapping).
  • Anonymous Dec 27, 2008
    Same here. I've had this problem for a couple of years. Static, crackling, fuzzed up sound on all output types except "Direct" or "Stereo" in which case the power is substantially reduced. There is no pattern to when it happens other than it happens more in winter months than in the summer. Any solutions that do not include expensive service calls?
    Scholar:
  • 54 Answers
The Denon Curse.......the connectors that the input boards ( up and down if your receiver is in the normal position ), plug into one of the 2 main boards on the bottom. These connectors are suspect and need to be cleaned and re-soldered. Same with the board that runs from the input side of the unit ( right behind the front panel, running across the unit ) to the amplifier board. Denons were HORRIBLE for bad connections with these. This is an involved repair requiring the entire thing to be pulled apart. It is not an afternoon job for a do-it-yourselfer, take it to an authorized Denon repair shop, as I GUARANTEE that they have seen this problem many times for all models from 2000-01-02-03. Good luck..... Rob
Posted on Apr 22, 2008
How to connect and set up my DENON AVR-3300 to my LG tv. Waht connections on amp and tv do I use?
  • if you want to listen your TV on your Stereo system thru your receiver, AVR-3300 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
AVR-3300 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
AVR-3300
Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Mar 28, 2011 | Denon AVR-3300 Receiver
I have a buzz / static that appears for the first 15 minutes.
Hi...
I just opened up an AVR3300..It's trouble is that it goes into stndby
at once.
The BIG power supply caps are VERY swelled at the top.
That would be my informed view on why it's bad.
I suggest you look at that being your possible trouble too.
Scott in Vermont
Jun 22, 2009 | Denon AVR-3300 Receiver
Fuzzy sound from front speaker
you have a small short in the connection of the unit.. it may be just bulid up which can be fixed by just blowing compressed air thru it. but if it more than that take to a repair shop as it could be an intenal problem
Apr 27, 2009 | Denon AVR-3300 Receiver
Denon AVR-3300 Center Chanel Sound Problem
My guess is You have dried out electrolytic capacitors causing failure. These receivers when they get over 6 years old start drying out fluid in capacitors especially on regulator p.c.b. causing noisy supply lines. I work for Authorized service center in Michigan If you need repair and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 06, 2008 | Denon AVR-3300 Receiver
The AVR-3300 power-off to stand-by mode
You have a blown amp or a leaky cap and the unit is going in to save mode to avoid destrying the unit.
Take it in for a repair. I don't think it should run more than $50-$75 for a fix depending on what component is bad.
Nov 19, 2007 | Denon AVR-3300 Receiver
Denon AVR-3300 Receiver Logo
372 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
