Question about HP Business Inkjet 1100dtn Printer
Documents print part way then stop
When sending a print job to the printer it will feed in the paper and print the first line then stops. Does not print anymore, does not feed the paper through. I am printing in grayscale only, black cartridge is almost full, printhead is still good. I have power cycled, reset via the management software, reinstalled drivers, reseated cables, all with no effect. The lights currently lit on the panel are: power light, paper feed light, ink light and the blue light. The last two are on because it has no blue ink - but that is why I am printing grayscale black cartridge only. I have to take the duplexer off the back to remove the stuck paper.
    Novelist:
  • 139 Answers
I've had similar problems in the past with my 1100dtn printer...there are several possible causes...it may simply be refusing to continue printing because the blue cartridge is completely out of ink...in spite of the black only setting.
Also, it could be some kind of software conflict, virus program, or spyware overload occuring in your PC...especially if the document you're trying to print is a large file, picture, or contains a lot of graphics. Try a test print from windows with other programs shut down.
Try completely removing the HP printer management software and then reinstall the latest version for your operating system from HP's web site.
A firmware upgrade may help. Firmware files and instructions are available on the HP web site. Mine printer has been running bug-free for about 18 months now...since I did a firmware upgrade. Firmware updates are complex...hopefully you'll find a simpler solution....but it may be needed, especially if your printer is more than a couple of years old.
Posted on Jan 18, 2008
My HL 2270DW won't stop printing goobldegook. One or so lines on each page, and the printer job does not show in the cue so it can not be cancelled. I can not print any jobs because of this malfun
Has it worked before? Many of these newer printers can print what are called Postscript documents, and you may have a Postscript driver instaled instead of the regular driver, or both and have selected the wrong driver when sending the job ORyou have an internal circuit board that'sgone bad
Jan 07, 2013 | Brother HL 2270DW Laser Printer
My HP P2015DN only prints one page at a time. If I have a 5 page document, the first page prints and then I must print the go button for each page to print.
Is the paper feeding from the manual tray or tray 2. If you are printing from tray 2 and have this problem then it is likely that your driver or software is looking for different paper types than you have loaded in the printer. For example, if you have plain paper in tray 2 and your software wants to print on letterhead, then the printer will stop after each page and by pressing the button you are telling the printer that it is ok to print on different paper. If you have the paper in the manual feed tray (tray 1) then I would check to make sure you are telling the pirnter to print to tray 1 and not manual feed when you send a print job.
May 02, 2011 | HP LaserJet P2015dn Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Printer won't print documents. Green light on
Hmmm, try feeding a sheet of paper into the manual feed slot... you might have inadvertantly sent a Manual feed job, and the printer is waiting for a sheet to be fed by you.
Feb 10, 2010 | Dell 1710n Laser Printer
HP PSC 2350 all in one printer Is not feeding properly and message reads paper jam. Paper feeds almost until it should have finished the job, but no printing at all has been done. It started making a...
This may not help everyone that I send it to, but it is worth a try.
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press
the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer.
The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Oct 15, 2009 | Computers & Internet
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Oct 23, 2008 | HP LaserJet 4100 Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Samsung SCX-4216F feed wheel
Clean the Feed Roller In the middle of the printer. Take the paper tray out- you will see the roller in the middle. Send a print job with paper tray removed. Press the black thing to fool the printer that it has paper. You will see the feed roller move. When it is in the position you want to clean- open the toner door and it will stop moving so you can clean it. Isopropyl alcohol and LINT FREE CLOG.
Nov 07, 2007 | Samsung SCX-4216F All-In-One Laser Printer
HP Business Inkjet 1100dtn Printer Logo
200 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
